Question about Foxconn 925XE7AA-8EKRS Motherboard
No video I am setting up a barebones kit and have made all the connections shown in the manuel, including the hard drive, floppy and dvd /cd burner. when the system was turned on, the lights on the case lit up, and the fans were running, but NO VIDEO! (There were no beeps either) I have tried reseating the cpu, putting in a different video card and resetting the cmos jumpers. What else could be the problem? Bad motherboard?
  • Professor60 Oct 09, 2007
    There's no way to check on this is there. I have heard from one computer tech here in Topeka that he's had nothing but trouble with Inter and socket 775. Is that accurate?
    I have ordered a new cpu. I hope it works!
    President:
  • 317 Answers
Does it appear that everything is booting up, hard drive spinning? But a blank video screen with nothing at all? I had this several times happen to me and it's always been a bad CPU.
Posted on Oct 09, 2007
  • Peter Burns Oct 09, 2007
    The only way that you can check to see if your CPU is bad is if you have another known working computer that has a motherboard with that same socket. Then you could put it in there and see if you have that same problem. But I'm 99% sure that it's a bad CPU, I've ran into this a lot in my repair business. I've never dealt with that specific board, but Intel typically makes good boards.
    Here's a site where you can buy a new CPU.
    http://www.geeks.com/products_sc.asp?cat...
    You might also check on ebay.
  • Peter Burns Oct 10, 2007
    When you install the new CPU, make sure you apply thermal compound between the CPU and heat sink. If not, you'll have an over-heating problem and your new CPU will be toast in seconds.
I installed ubuntu 9.10 on my pc with wubi...it installed i install apps and games on it...i was happy and turned off it...after 2 hours i run the pc it shows ntldr is missing...what is reason and how i...
first check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppy drives ,and no removable usb drives plugged in to the usb ports
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
hope this helps
May 05, 2012 | Intel Computers & Internet
Display is blank, drives are dead,
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 25, 2011 | Rimage 2000i Burner
This device cannot start. (Code 10)
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
Check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppydrives.
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Feb 02, 2011 | Teac CD-Rewritable W28E CD-RW Burner
Pc turns off when inserted a cd or dvd
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
make sure all leads that are attached to your drives ((dvd\cd)) 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 21, 2011 | Computers & Internet
Hp dvd1260i is not work normal pc cant RECOGNIZE dvd drive For normal working need to shut down pc and again power SUDDEN Recision power from hp dvd1260i thanks 4 Help
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
hope this helps
Dec 28, 2010 | HP DVD1260i DVDRAM Burner
I have problem with my driver . it's not reading any CD or DVD and not ejecting the CD
or you might try
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Dec 21, 2010 | Hitachi HTS542525K9SA00 250 GB SATA Hard...
Got a hard drive error. Replaced it and when trying to reload software, it will not recognize the new drive. Is there a special boot disk I need to use other than the recovery disk?
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
not sure which drive you mean
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 13, 2010 | ASUS (90N804SH021) Hard Drive
Says boot disc not found. doesnt recognize my HD's i've also tried to flash my bios and that didnt work
Be sure to enable the IDE and or PATA/SATA controler in the BIOS settings. Set first boot device to main Hard drive.
damnor01
Dec 11, 2010 | Abit Fatal1ty AN8 SLi Motherboard
Problem for Dell PowerEdge 2450 Server CD/DVD ROM
Its doubtful that its the cables. Can you tell me what type of DVD/CD you have? For example SATA or IDE. Look at the picture below, these are hard drives but the connections on the optical drives are the same>>>>>
If the interface is IDE then check the jumper settings if they are both on the same cable.
Also check another CD/DVD in the drives.
Let me know how you get on.
Regards.
Jul 01, 2010 | Computers & Internet
Jumper
Does the cord going to your CD-RW hasve asnothe plug further down the line most computers can connect 2 cd type drives!!!
Jan 02, 2008 | Pioneer (dvr-a06u) DVD±RW Burner
Foxconn 925XE7AA-8EKRS Motherboard Logo
Top Foxconn Computers & Internet Experts
Alun Cox
Anders Bergwall
Anders Bergwall
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
