Question about Ryobi Rj162v Reciprocating Saws
Disassemble Blade release lever broke. How do I disassemble and replace?
Dewalt dc385 blade replacement
This clamp design is not going to win any engineering awards for sure. These are very susceptible to getting packed with junk and if you disassemble, clean, lubricate it with Silicone spray and reassemble it should help tremendously. (Don't use WD40 or oil as these will attract and hold dirt and dust compounding your problem)
If it still hangs up I would replace the actuating lever - they tend to get bent / gouged and don't move the clamp all the way open.
Lastly, it there is a lot of side to side play in the shaft itself that could be the issue because the lever can't mover the clamp all the way. (If this is the case you will find it cheaper to purchase a new one than repair this one)
Jul 30, 2016 | Dewalt Saws
Remove blade from master force saws all
  • 1. Disconnect the saw from the power supply.
  • 2. Open the blade-clamp release lever.
  • 3. Insert the saw blade into the blade clamp as far as it will go, and release the blade-clamp release lever to lock the blade in position.
  • 4. To remove the blade, open the blade clamp release lever and pull the blade from the clamp
Blade cannot be removed Saw dust in the clamp slot
Clean the clamp slot with brush
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=masterforce+saws+manual
Dec 09, 2015 | Saws
Ink release lever in brother MFC-6490cw broke
Did you ever resolve issue with broken tab. I have same problem on my black cartridge release tab, and am wondering if I can need tab or can salvage. Thanks!
Nov 17, 2012 | Brother MFC 6490CW InkJet Printer
I had to disassemble the tool-less blade clamp on my Ridgid reciprocating saw. When I reassembled it the retention pin no longer moves back and forth when I flip the blade change lever (not sure if...
The spring loaded clamp sleve mechanically holds the blade pin down to hold the blade in place. It doesn't pull it up to release the blade but simply lets the pin float freely so the blade can be removed.
Sep 06, 2012 | Ridgid R3020 27248 12 Amp Twist Handle...
Zanussi FL1012 tenants broke off external door catch. I have bought new catch, how do I release the door to open it without the handle? to replace it with with new handle, only the end bit of the handle is...
there is a lever if you can pry it open a bit and get some type of hook in there and pull it across you can get it open i can get it with just a flat blade screw driver but a have had heaps of practice
Jan 05, 2011 | Zanussi Washing Machines
Blade stuck in reciprocating saw
The pin is probably stuck in the blade. This happens from time to time after they get dirty. Take some WD-40 or some other type of penetrating oil and spray a little in the blade holder while working the release lever. It will probably free right up.
Apr 24, 2010 | Craftsman 8.0 amp Reciprocating Saw
The blade lever on my sawzall is stuck in the up position
oohh, that a tough one. you gotta, very carefully peal back the hand gaurd, the rubber where you hold onto it, at. Then releas the screws undeneath. Seems like you should be able to cycle the saw to its furthest out position, then remove the blade gaurd, uning some pliers of some sort you should be able to make the release, release.
Hope this helps
Mar 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
Pentax ME Super
Does the film advance lever lock in place when the lever is returned ? if not, the lock spring broke. This is a common weak point in the ME Super. the camera must be partially disassembled to be repaired. get a cost estimate first. there are no new parts for this model Pentax.
Jan 04, 2010 | Pentax ME Super 35mm SLR Camera
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
Ryobi Rj162v Reciprocating Saws Logo
165 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
