Question about E-Machines H2824 PC Desktop
No power after external power failure
I have an eMachines H2824 tower that went out of warranty 2 months ago (conicidence??). Yesterday, possibly due to a severe power outage (the power came and went 3 times, with loud bans coming from a piece of equipment in the street outside, before staying off for several hours), the tower went dead. That is to say that it will no longer turn on at all. I checked in Troubleshooting in the accompanying booklet and it suggested that after an external power failure it is necessary to unplug the machine from the wall, wait 10 secs, and replug before pushing power button. This did not work either. Anyone able to suggest the variety of technical problems that may be involved here, and especially any bright ideas for attempting to restart the machine without having to take it to a techy? Thanks...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
The first thing I have to advise you is to change the Power supply unit. Before buying one change it with another one (probably from a friend's PC) and see if it is working. To remove the power supply unit, you need to remove your tower's case, and unscrew the power supply and remove it. the power supply is the metallic box on top of the computer at the back.
Posted on Oct 08, 2007
SOURCE:
Inspiron 620 desktop will not power on. Change out of power cord was done whilst under warranty (7/12-7/13). Purchased 7/13. Warranty is up. Have not tried to power on since August--it powered up then....
A computer will not power on in certain conditions follows
  • RAM Failure. i.e, RAM is not properly inserted into the port, or any dust particle presence in its port, I am sorry to say The RAM is in DEAD condition
  • Mother Board Failure. Any overflow of power enters into the motherboard. motherboard will burnout (due to lightning, Voltage level increasing etc)
  • Power Failure
  1. When the power cord is properly functioned or loose connection
  2. SMPS is under malfunctioning (SMPS Burn out)
  3. Power cords from smps to mother board,HDD,CD drive fail
  4. Short circuits etc
Check it out...
Jan 22, 2014 | Dell Inspiron 620 ST Desktop Computer...
HP Pavilion a6602f suddenly stopped working for no apparent reason.
Hello there, I am the Expert that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Debdeb_64.
The power supply could be ok, this little green light that you see on the rear of the tower case is likely to be the Ethernet/Network connection.
Possible reasons for failure are as follows:
It could be a loose connection at the 24Pin or Processor 4Pin power connector.
A damaged power supply, is possible.
A faulty power on switch.
A dead mainboard.
A loose connection.
I have published a few guides that should help you in this regard, they are entitled:
How to Remove the Side Panels of My Computer Chassis!!!
How do I reset my BIOS/CMOS to defaults?
and most importantly My Computer is not turning on!!! Is it dead!!! No POST!!!
Do contact a computer technician to test components if need be.
Take care!
Feb 03, 2012 | Computers & Internet
I have an emachine model 390 (possibly) which is in trouble. yesterday I found it with its power switch constantly flashing & making a clicking noise. I was unable to turn it off by the switch on the...
Hi Nicki,
Sorry, this really sounds bad, it would seem that the hard drive is shot from your description. The data may or may not be recoverable. If you get a new drive, you will have to partition it first, then set it as your Master drive, then set the old one as a slave, install your operating system onto the master drive and try to recover the information on the old drive after you have that done. If you cannot successfully recover the information that way, you most likely won't be able to get it at all unless you backed it up onto a flash or cds or dvds.
Sorry for the news but that is what it sounds like
Joe
Sep 17, 2011 | E-Machines eMachines Desktop PC
I have a t3303. my external speakers suddenly stopped working. they work perfectly on my cd player and my headphones work perfectly in the headphone jack on hte tower?????
Check the settings for your speakers in the sound settings. It is possible that the settings have changed. It is also possible that the sound card has went bad in that port.
Jul 17, 2010 | E-Machines eMachines Desktop PC
Installed a generac 10k guardian standby generator 2 months ago and all was well,self test each week went fine until this week. Seems to have lost power, screen blank and can't reset? How can I get this...
If you installed this 2 months ago, then you are still under warranty. You need to contact Generac directly before you try to fix yourself and void warranty. Not trying to offend, just being practical.
May 17, 2010 | Electrical Supplies
Yesterday my friends emachine ET1331G-03w just bought 2 months ago, due to microsoft software updates issues upon restarting her computer won't start windows due to problem above, we tried to do f8 on...
As the computer is only 2 months old, you should be able to contact Emachines and have
them send you a recovery disc out for the particular model. As the computer may seem identical, in most cases a recovery disc from your computer will not work because of a different
driver or some other small issue.
Feb 12, 2010 | Gateway Computers & Internet
Power will not stay on
With a problem like this, I would use the warranty for the TV.
It's possible a circuit board failure has occurred and the TV is automatically turning itself off to protect it from further damage. Is normally called " Protection Mode " for most TVs.
Being that it's 2 months old, it should be under warranty regardless. I would recommend contacting the store of where it was purchased and have them help you with the warranty issue.
May 04, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Emachine keyboard went out
hi
if you have to back up all the programs that u need it try to open your
desktop tower and then pull out the hardisk and then put it in other computer and installed your
driver of your keyboard and then out it back to your original tower!!!!
Sep 17, 2008 | E-Machines eMachines Desktop PC
Video issues
Posted same response on the other Zenith issue...
I've owned this unit since Dec 2005. It appears there are two Video Amp boards Z & Y-SUS boards, that have failure problems.
After 10 months, my ZSUS board went out and was replaced under warranty. And... Just a month ago, the same problem occured again, so I've complained to Zenith (LG) and they are extending my warranty to repair the unit.
Nov 15, 2007 | Televison & Video
Tv went black
Nov 01, 2007 | Televison & Video
Open Questions:
See all E-Machines H2824 PC Desktop Questions
Computers & Internet Logo
73 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
