Question about Rotary Hammer Drill Metabo Uhe 28 Multi W/2 Chucks
How do I change the brushes in a Metabo UHE 28 Multi
3 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: It will not work with my power inverter in my
The inverter isn't putting up enough power to drive the metabo. You may be able to give it a "running start" by rotating the blade along a board while pulling the trigger. This isn't a good practice, however, as the board or the saw could slip, so be doubly careful if you try something like this. Your best choice would be to get a bigger inverter.
Best regards, (and be careful), --W/D--
Posted on Feb 07, 2011
  • 14 Answers
The Metabo UHE28 has the Metabo Electronics. The electronics in the tool is designed to read a true sine wave. The power inverter in your truck changes the DC current to AC and puts out what is called an artificial sine wave. These two are not compatable. In short the electronics in the drill does not like inverters. It will not work.
Posted on Oct 08, 2014
Hi I have a metabo hammer drill une 2850 won't start
UHE2850 metabo first look if its the powercable have no phase fracture second is there depending 2 years warranty time on left ?
The switch or only dirt between brush and brushholder inside or an electronic assembly defect or the switch electric field armature . only a slide contact loose sometimes its not hard to find by metabo machines.
Mar 26, 2016 | Metabo Drills
Metabo uhe 28 multi code
http://www.metabo.com/International-Homepage-english-The-craftsman-s-brands-world.2786.0.html?&L=2786 You have no question but I do see the name metabo so hope this helps. It's the Metabo factory site where you can get parts breakdowns and more.
Jan 04, 2013 | Rotary Hammer Drill Metabo Uhe 28 Multi...
How to do maintenance on metabo sbe710
for maintenance:
after use
1: cleanup with air pressure(inside of motor by motor vent)
weakly
2:clean chuck with brake cleaner and lubricate with metabo grease
at 3 month
3 check motor brush
when motor brush are worn,check ball bearing on armature,extended motor cleanup,gearbox check and grease change if it is dirty,
Oct 10, 2012 | Metabo Sbe710 1/2-in 0-1,000 / 0-3,100 Rpm...
Drill does not work when i press the trigger
Did you take a look at the carbon brushes?. Metabo has what they call Auto stop Carbon brushes. so if they are worn down they will pop away from the motor and the drill will simply not run. this happens when the brushes are basically worn out.
Mar 16, 2012 | Metabo SBE1010PlusC 1/2" 0 900/0 2,600 Rpm...
Metabo SBE 750 Have continuity through the trigger
IF you have continuity through the switch and the brushes look good then remove on brush and look at the commutator segments. There should be nice even gaps between each segment. If you have on that a goodbit wider than the others then your rotor is bad. If not then more than likley your stator is bad.
Aug 06, 2011 | Metabo Drills
1/2" metabo hammer drill-
Did you check the carbon brushes?
May 17, 2011 | Metabo Drills
No power to bite
Needs new brushes. http://www.metabo.com/Spare-parts-lists-handheld.16913.0.html
When the brushes wear down they are held back by there power wires.There should be a set of small holes in the brush holders.Push new brushes to the bottom and put a wire through the small holes to hold brushes in place during reassembly.Pull out the wires and the new brushes will seat. Brushes don't cost all that much.
May 07, 2011 | Metabo GE700 Grinder
It will not work with my power inverter in my truck, but it works when used on a regular 120v outlet. My power saw and my HILTI Drill work but the METABO UHE 28 Multi just will not work at all??? WHY ???
Feb 06, 2011 | Rotary Hammer Drill Metabo Uhe 28 Multi...
Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
Rotary Hammer Drill Metabo Uhe 28 Multi W/2 Chucks Logo
Top Rotary Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Rotary Drill Expert? Answer questions, earn points and help others
