Question about Stihl 440 044 460 046 Chainsaw Clutch Drum
My chain wont tighten on my stihl 044 chainsaw
  • 39 Answers
Assuming you have the right length chain and its not just running out of adjustment, it would then probably be a stripped or snapped chain adjuster. Can be coursed when the bar nuts aren't dun up before starting to cut, the force of the chain saw will snap an adjuster no problems. If its striped it might smear like its adjusting in but when it gets to a point it will just stop
Posted on May 06, 2014
3 Suggested Answers
  • 6468 Answers
SOURCE: Tension screw won't tighten the chain on a Stihl MS660
remove the cover and look to see if the tab is broken off
Posted on Apr 15, 2012
lazy22
SOURCE: chain oil leaking on 025 stihl chainsaw
Their is a oil passage that has a plastic plug in it by the muffler. It might be gone like mine is.
Posted on Oct 04, 2012
Stihl 044 bogs out when cutting
Chain brake ok? I know one that won't let me stop the blade running but then cuts out after a short time...
Jul 25, 2014 | Stihl Garden
Stihl 046 floods
the needle in the card may not be closing all the way
Feb 09, 2014 | Stihl Chain Saw Handle Models 044 046...
Chain keeps comming off my stihl 044
Download manual at:
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/044_Manual.pdf
Go to page 26. Remember to pull front of chain bar up before you tighten nuts. Make sure you really tighten nuts so they do not allow bar to move when finished.
Nov 20, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How do you start a STIHL MS460 chainsaw
I am a Stihl mechanic. The proper starting procedure is to set the switch to full choke. Pull the starter rope no more than three times.Now raise the switch up one notch and pull it till it starts. Stihl products will flood if pulled more than three times with the choke on. Thanks, George
May 08, 2012 | Stihl Chain Saw Handle Models 044 046...
Apr 14, 2012 | Stihl Models 064, 066, Ms640, Ms660
16" chain, 16" bar it
You're not tightening the nut tight enough.
Apr 17, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Iginition coil test for sthil 044
If it makes a blue spark, it's probably good. More orange, probably too weak.
Mar 08, 2011 | Stihl Chain Saw Handle Models 044 046...
044 stihl sawchain wont idle just dies out and sometimes runs at high idle
This sounds like an air leak. Checking all of your hoses and making sure the crankshaft seals are good is where to go after adjusting the carburetor to factory settings.
remove the muffler and make sure the engine does not look like this:
barterjoe_9.jpg Consult a gold certified Stihl dealer like www.arcolawn.com for parts and tools to repair all of your Stihl equipment.
Good luck
Dec 15, 2010 | Husqvarna Chain Saw 20" Bar
I have a stihl chainsaw model #311y and I need to tighten the chain .Can you help me?
loosen bar nuts, with gloved hand push up on bar, and turn adjuster screw clockwise. on stihls it's either beside bar facing forward or between bar nuts.
Feb 05, 2010 | Standard Oregon Chainsaw Chain For Stihl...
Stihl chain saw
shut off the engine
pull out the hinged clip and loosen the wingnut
turn the adjusting wheel clockwise as far as stop. (on top of the adjustment wingnut).
tighten down the wingnut firmly by hand
fold down the hinger clip.
go to the following link, if you need the users manual.
http://www.stihlusa.com/stihl_ownersmanuals/MS210230250_Manual.pdf
Apr 09, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Stihl 440 044 460 046 Chainsaw Clutch Drum Logo
93 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
