Hp 584037 001
Computer won't even turn on power button won't work tried power reset, didn't work tried with/without the battery, didn't work
Benimur
  • 6966 Answers
SOURCE: Computer does not turn on
The only easy check I can suggest is for you to have a look & see the memory underneath the laptop. It should be covered by a squarish panel/lid held by a screw (or 2). You can try wiggling it or best remove it by moving the 2 locking clasps at each side slightly away making the memory pop out. You can now remove the memory and clean the little gold tips/connectors using a pencil eraser. Reinsert and try again.
Other than the above, would suggest that you bring it back to your dealer/supplier since any further action on your part would void your warranty.
Good luck and kind regards.
Posted on Oct 23, 2007
SOURCE: unable to start laptop
I understand the urgency and also the importance of data stored in the laptop.
As the laptop is unable to start in normal mode let us try in safe mode.
Follow the steps below:
1. Turn the laptop off completely.
2. Press the power on button to turn it on and at the same time simultaneously keep tapping ' F8 ' key on key pad until you see a advanced boot options screen.
3. Select 'safe mode' and hit enter.
Thank you.
Posted on Nov 28, 2008
  • 80 Answers
SOURCE: I have an HP Mini 110. I have turned off the
Try this: Remove Mini from A/C power; remove battery. Hold power button for 10 seconds; reinstall battery & A/C power. Try starting normally. Your netbook doesn't appear to have an external VGA port, or I would suggest trying to connect to an external monitor. Your monitor back-light may be burned out.
Posted on Mar 10, 2010
  • 1288 Answers
SOURCE: Hp pavillion dv2500 will not
If the laptop will not physically turn on (as in no led's), check the following in order:
Also check the RAM is seated correctly, remove the hard drive and test without it being in the laptop
Then:
  • Check the charger led is steady, a flashing led points to power not making a circuit and being "spat back".
  • If the charger LED is steady check then the power outputting from the charger with a multimeter, set to 19 volts DC, red probe to the inner of the jack, black probe to the outer, a drop in voltage indicates a charger not properly working.
  • If the above are ok, check the security of the charger port, if this feels sloppy or loose, it will need replacing as it is not pulling power to the board (on this model I THINK there is a wired port..not a hard soldered port, you may find that if it is the former, the wire has developed a short and you may need to replace it.
  • If the above are ok and either the charger led is flashing or power is not making it to the board, check for a small ceramic fuse near the charger port on the motherboard, put a multimeter across both sides with the meter sets to Ohms and see if current is making it across the fuse, if it is not, it required repairing or bridging.
  • After that, you have a fault on the motherboard in the power circuit and will need to consider replacing the motherboard
Posted on Jul 22, 2011
bronk50
  • 27725 Answers
SOURCE: HP compaq 6730s laptop won't turn on
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
might be getting hot
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps you
Posted on Dec 10, 2011
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
It turns on, but nothing else
take out the batteries; remove cartridge. press hold power button for 30 seconds. place batts back in and try to turn toy on
Oct 05, 2012 | Vtech V.Reader Interactive Reading System
Dos not work
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch.
Press any button to turn on iPod.
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
hope this helps
Sep 05, 2012 | Eclipse Audio Players & Recorders
Panasonic DMC-TZ3: one day it's working fine, next it won't power on. Tried the "Power Saver" reset technique posted ... didn't work. Battery is fully-charged.
Hello
Try removing the battery and the memory card for 1 minute then return them back. Make sure the battery is inserted properly. If that didn't work, try turning it on without the memory card.
Did you get any error message when you try to turn on your camera?
Sep 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Computer is frozen
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jun 10, 2010 | HP Pavilion DV6700T Notebook
My Zune HD won`t turn on, what do i do ? =]
Hold the power button for 10 seconds. this should cause reset. if it does not hold it again for 15 seconds this should cause it to power into repair mode where you will then need to plug it into your computer and update the firmware with the included software. hope this helps!
Apr 15, 2010 | Microsoft Zune HD MP3 Player
I purchased a Compaq CQ50 laptop 2 weeks ago. I was working on it and walked away for just a second. It turned off and will not turn back on when I push the power button. The power button on the fron of...
Try taking the battery out and starting it without the battery. If this doesn't work, contact Compaq (HP) immediately and take advantage of your warranty.
Oct 30, 2009 | HP Compaq Presario CQ50-110US Laptop
The PC is not switching on
Hi. I assume that you plugged in your original battery after it was out a while. When your device's battery is drained, all the data in your device may be resetted (changes according to your backup battery's condition). So you should first try to plug it into AC power source for a couple of hours without touching it (Let the battery become usable enough). Then, your device should open without any error, but it may take a while because it will install the Operating System from ROM. In most cases, pluging out your battery won't destroy any internal parts of your device, it may just reset it to factory default settings. If there is an error, here is how you can hard reset your device:
HP iPAQ rx3715 Hard Reset:
1. Hold down the Mobile Media button (on the far left) and the iTask button.
2. Then press down the reset button with the styles for a few seconds until the screen goes dark.
3. To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Hope this helps.
May 31, 2009 | HP iPAQ RX3715 Pocket PC
Unable to start laptop
Thank you.
Nov 28, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
