Sharp AR 1356 h4 problem
I pressed hash interrupt button then c interrupt button within 20 seconds, machine does not shut down ? What's is the problem going on.
  • 37 Answers
SOURCE: SHARP AR 5316 error H4
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Posted on Mar 01, 2009
  • 32 Answers
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Posted on Mar 25, 2009
007tech
  • 95 Answers
SOURCE: dispays h4 error
An H4 error code indicates trouble in the fusing section - a certain temperature has not been reached within a specified time. It could mean a dirty/bad thermistor or dirty/bad thermostat (both inside the fuser unit. Make sure both of these are clean and there is not debris/paper stuck inside the unit.
You can try resetting the code by : Get into SIM mode by pressing the following keys one after the other "#" "interupt" "C" "interupt" then enter 14 and the start key - confirm if requested then make sure the copier restarts.
Hope this helps.
Posted on Apr 18, 2009
007tech
  • 95 Answers
SOURCE: system error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
Posted on May 20, 2009
  • 7 Answers
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Posted on Jun 10, 2009
Sharp AR-M258 Error Code H4-20
If any one faces error H4 problem on sharp AR 258
press fast the below keys and 99.9% on the case will be solved.
1. Press #, interrupt, c, interrupt or Press #, * ,C, *
2. Enter 14, press start
wait for few seconds and it will work
Mar 22, 2011 | Cameras
The SHARP AR-5320e is blinking H and then 4 I changed the toner but it keeps doing the same thing.
H4 trouble can be cancelled. press #-interrupt-C-interrupt simultaneously. after that machine panel will black-out hence you can STILL input 14 (in numerical buttons). press start/copy button. Yala--ur machine will initialize again. hope it helps
Feb 12, 2011 | Sharp AR-5320 Black and White Copier
Solution TO sharp photocopier ar-5516 4 H error
Press the following buttons fast: #, interrupt, C, interrupt, C, 14, Start button.
Oct 06, 2010 | Sharp Office Equipment & Supplies
H4-01
Dear sir h4 signal is fuser unite please you call a technician and solve your problem
Aug 12, 2009 | Sharp AR-507 Copier
Irc2105
There is no such error 'E215-0000' in ar 5320, for H4 use "#, Interrupt, C, interrupt. Display goes off, Enter 14, Press Print key.
Apr 08, 2009 | Sharp AR-5320 Black and White Copier
Showing h4
If your machine is AR-5316,
Mar 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
Mar 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Sharp AR-M237 DISPLAY READS CALL FOR SERVICE CODE H4-20
ussually h4 appears when the heater lamp is busted. but to really be sure just simulate C # C interupt (enter )04 then press start. if problem persist. chect the lamp and if find busted repalced it.
Dec 16, 2008 | Sharp AR-M237 Digital Copier
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
k24674
