Driver for icp con 7561 - Computers & Internet
Hi my name is phil
- Faulty Injection Control Pressure (ICP) sensor
- Injection Control Pressure (ICP) sensor harness is open or shorted
- Injection Control Pressure (ICP) sensor circuit poor electrical connection
- EGR system fault
Aug 19, 2014 | 2003 Ford Focus
Help 68538702001
Here's what I would try first:
  • Open Device Manager and look at the properties of the device and all USB Root Hub entries. Under the Power Management tab, deselect the check-box for "Allow the computer to turn off this device to save power".
  • Don't let the computer go into Sleep mode under Power Management.
Also, I would think a serial device might draw a lot of power, getting pretty close to the 500 ma limit imposed on USB ports. The device might be more dependable if connected to a powered USB hub, which might not have this limitation.
Dec 12, 2013 | ICP DAS I-7561 CR (I7561CR) Serial Adapter
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
Sep 13, 2011 | 2000 Ford Taurus
F-250 diesels blowing white smoak? Why?
More than likely your loosing fuel pressure, you may need a new under hood fuel filter and the low pressure pump located on the frame rail on the driver side of the truck. The ICP sensor (Injector Control Pressure Switch) could also be bad and cause this. But normally if your blowing white smoak and your loosing power at the same time I would say fuel pressure. But if your not loosing power and just have white smoak I say ICP sensor. Also check your engine oil, if its low or extremely dirty, this can cause this also. It uses the oil pressure to run the ICP sensor to control the injectors.
Jul 22, 2011 | 2005 Ford F 250 Super Duty
WHERE IS THE ICP SENSOR LOCATED ON THE 6.0 2003 F-250 MANUFACTURED 4/03
the icp sensor is located on the passenger side valve cover !
Jun 13, 2010 | Ford F-250 Cars & Trucks
Do you know how to fix the code - P2285 (ICP) on a 2003 Ford 350 6.0 diesel truck
DTC P2285 indicates the injector control signal circuit is out of range
so its either the ICP sensor located ontop of the passenger valve cover
or an open or shorted wire between the pcm and icp sensor
Jan 26, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
Not sure how the blade seats in saw pneumatic bosch jig saw i can get it to go in but the blade seems to wander and seems to be unstable
do you have the screwdriver that came with the saw? if not you need a longer straight slot screw driver and it must be ground down to fit into the blade clamp tightener. it is a narrower than usual screw driver. I lost mine and had to custom make one. good luck.
Sep 14, 2009 | Bosch 7561 - 118 Pneumatic Cutting Tools
I have a 1997 7.3 that misfirers when starts wont stay on losses power wh3n driving and shuts off. codes from diagnostics is p1211 ICP not controllable and p1282 excessive ICP
you need to replace icp its in the back under the turbo its a little sensor fairly cheap and a pain in the but to get to good luck
Aug 12, 2009 | Ford F-250 Cars & Trucks
WHERE IS THE IPR LOCATED ON THE ENGINE ?
The "IPR" is and Injector Pressure Regulator. It is a Solenoid used to control the oil pressure created by the High Pressure Oil Pump. The IPR is capable of regulating oil pressure from 0 to 5000 psi. On an 05 6.0l the IPR is located in rear, top, center of the engine in the High pressure oil pump. It can be identified by its gold color. It sticks out of the side of the pump pointing toward the driver side of the truck. It has a 2 wire plug that is held on by a metal clip. usually the ipr and plug are protected in a heat shield so you may not be able to see it right away. Some people mistake and IPR for and ICP. The ICP is a sensor that tells the PCM what the High oil pressure is. ICP stands for Injector Control Pressure. This sensor is located in the passenger side valve cover on and 04, 05 6.0l and in the top of the High pressure oil pump on an 03 6.0l.
Nov 06, 2008 | 2006 Ford F-250 Super Duty
Driver incorrect
Hello, look the device VID & PID in
Control Panel --> System --> System Properties --> Unknown Device --> Details
Es. I Found on my notebook : USB\VID_067A&PID_7561\5&1737F18D&0&2
Then Modify SER2PL.SYS with your VID & PID
Es. :
[ControlFlags]
ExcludeFromSelect = USB\VID_067A&PID_7561
[Pro]
%DeviceDesc% = ComPort, USB\VID_067A&PID_7561
Reinstall the driver
Aug 05, 2008 | ICP DAS I-7561 CR (I7561CR) Serial Adapter
Computers & Internet Logo
579 people viewed this question
David Payne
David Payne
