Question about Foundry Networks Foundry EdgeIron 2402CF (EIF2402CF) Networking Switch
How to connecting to switch foundry - Foundry Networks Foundry EdgeIron 2402CF (EIF2402CF) Networking Switch
Logo of The Foundry
Hey Gunney do you have any website address?
Mar 15, 2013 | Logo Wine & Spirits
What are the advantages of a cast iron wok?
when cast iron woks are seasons properly, they help create the special 'wok style' flavor. They also have good heat retention and cook the food evenly.
Feb 18, 2013 | Home
We have foundry edgeiron 2402cf switch and forget my username and password , what i shoud be made ?
Please follow the steps below to reset the password
1. Power Off and Power ON the switch
2. Immediately enter 'b' to go to the boot monitor mode
3. Do not Enter any password in boot monitor mode.
4. Enter boot system flash primary
5. You will be getting a prompt as 'FastIron>'
Please set the new password as below:
FastIron>enable
FastIron# configure terminal
FastIron(config)# enable super-user-password admin
FastIron(config)# write memory
Your new password is set now as 'admin'
Best Regards
Nov 10, 2010 | Foundry Networks Foundry EdgeIron 2402CF...
Not booting
power cycle -if poe try connecting voip phone via cat5 to port 1 or 24 then power cycle
Nov 25, 2009 | Foundry Networks Foundry FastIron Edge...
Recover Password
there are two ways ..try them
first :
In order to set a new password do the following:
Make sure you have a console connection to the Foundry device.
Reset the device using the reset button in front or remove and then reinsert the power cable.
Immediately enter b to go to the boot monitor mode at the time of boot up.
Enter no password in boot monitor mode.
Enter boot system flash primary (or secondary).
At the prompt enter the following commands:
FastIron>enable
FastIron(config)# enable super-user-password test
Your new password is now "test".
second... only try if first doesnt work
Set the switch to its default configuration. Make a direct connection to the switch’s console port and power cycle the switch. Immediately after powering on, press <Ctrl><u> to access the system file menu. ]Select <D> to delete all user-defined configuration files. Press <Q> to boot the switch.
hope this solves your problem
Aug 08, 2009 | Foundry Networks Foundry EdgeIron 2402CF...
I am facing problem with foundry switch x424 . frequently its shutdown
Check the power supply, find a replacement supply to try, this might help.
Jan 04, 2009 | Linksys Wireless-G WRT54GS Router...
Hub and switch difrance
Switches are smarter than hubs.
Lets say you have a switch with 16 ports, your computer is connected to port 2 and you are browsing the internet. You make a page request and when the reply comes back it hits the switch and the switch forwards the information to port 2.
This does not happen with a hub, the hub does not know you are on port 2, it sends the information to every port, in this case all 16 ports. In a low traffic environment a hub can be ok but it can cause a lot of unnecessary traffic on your network and slow it down.
If you have a choice pick a switch over a hub, there is not that much of a price difference these days.
Sep 26, 2008 | Foundry Networks EdgeIron (EIF48GS)...
Edgeiron 48gs
The RJ45 pin color configuration is mismatching
Oct 17, 2007 | Foundry Networks EdgeIron (EIF48GS)...
Foundry Networks Foundry EdgeIron 2402CF (EIF2402CF) Networking Switch Logo
Top Foundry Networks Computers & Internet Experts
David Payne
David Payne
Are you a Foundry Networks Computer and Internet Expert? Answer questions, earn points and help others
