Question about Intel Dot Station (INTC300AIO) PC Desktop
Not able to connect the Modem
When I tried to hook-up the telephone line and dial-up, the system repeatly fails. I suspects either some settings or connection issues. Can I know, where I can get the English version of user manual, so that I can further explore - Artha
  • 1 more comment
  • Artha Oct 09, 2007
    I want the English version of user manual for Intel Dot station, what I have with me is a European edition.
    Since I am not able to connect the modem, I want to check whether changes are required in system settings as defined in the User manual.
  • Anonymous Feb 10, 2008
    I need eng manual of Intel Dot
  • Anonymous Sep 29, 2008
    i have the same problem of not recognising,, the Modem driver, for Intel dot station.
    In Short, Dot station sucks.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
User manual of what? your modem user manual? which is your modem's model?
Posted on Oct 08, 2007
SOURCE:
Off the hook
A "Phone Off Hook" message is not an error. It simply indicates that a telephone receiver isoff the hook(the handset is lifted) and the telephone line is open. This message would be expected in the following situations:
  • A modem on the phone line is accessing the Internet.
  • A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.
  • A credit card machine is using the phone line.
  • Another electronic device is using the phone line.
  • The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.
When the other device is no longer using the phone line, the display should revert to the normal message.
Lets try the following,
Disconnect the phone cable from the back of the HP product and the message should clear. If the message does not clear, unplug the power cable from the back of the unit, wait 15 seconds, and then plug in the power cable.
if issue still exists try the followign
Disconnect the phone cable from the HP product and connect it to a single line phone. Pick up the handset and listen for a dial tone. If no dial tone is present, replace the phone cable. If a dial tone is still not present, a problem exists with the phone system.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Apr 22, 2014 | HP OfficeJet 4215 All-In-One InkJet...
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Can you hook up dial-up to a dsl modem
Can you hook up a dial up what to a dsl? A modem? No, you need a dsl modem for a dsl line. Typically, a dial up is POTS (Plain Old Telephone Service) and connects to a POTS 56,000 K modem. DSL will run much faster but not as fast as cable.
Jun 05, 2011 | Computers & Internet
Can not phone out or receive phone calls bt say my line is ok, my broad band works ok but not my phone
When did it start?
You haven't mentioned what you hear when you lift the receiver and try to dial out.
Please try this: (A process of elimination.)
- Unplug your modem from the telephone line.
- Plug your telephone directly to the telephone line without going through the line filter.
- It should work OK. If the phone is not defective, you should hear a clear dial tone.
- Now connect your phone through the line filter and try to use it again.
- If it does not work then you need a new line filter for your telephone.
- If it works, then re-connect your modem back to the telephone line like it was before.
If the modem knocks out your phone again, please contact the modem supplier.
May 31, 2011 | Office Equipment & Supplies
Made unsuccessful attempts to connect to the Internet using the dial-up modem. The internal modem came installed on my original PC and is a Smart Link 56k Modem. What do I do?
Can we have more information about the problem you have when attempting to connect ? The error code and message would me very useful in your case.
For example :
1. If it says the modem is already in use, go to "Network connections" or "Network and sharing center" and delete all existing dial-up connections, then create a new one based on the settings your internet provider gave you.
2. It might be a problem with the login and password. Write both in Notepad on the computer, then copy and paste the information in the required fields in the connection window.
3. It might also be a problem on the telephone line. Try another computer with dial-up modem known to work properly. If the problem repeats on that computer, the problem is on the telephone line. You will need to contact your provider to fix the problem.
May 05, 2011 | Smartlink All 56K Modems: V.92 PCI Chipset...
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
How do I use the fax without going thru my computer just as a fax
Issue: How do I connect a telephone, answering machine or computer modem to my machine?
Solution: Connecting the telephone line and external devices to the MX310
Preparing the Machine for Faxing title-bar.gif Typical examples of connecting the machine are described below. The machine cannot send/receive faxes if the connection is incorrect. Connect the machine correctly.
i_important.gif Important
If the Power Disconnects Unexpectedly
If there is a power failure or if you accidentally disconnect the power cord, the date/time settings as well as all documents stored in memory will be lost. User data and speed dialing settings are retained. If the power disconnects, the following will apply:
bullet_s.gif You will not be able to send or receive faxes or make copies.
bullet_s.gif If a telephone is connected to the machine, you can receive voice calls.
bullet_s.gif Whether you are able to make voice calls depends on the type of your telephone.
sikaku.gif Methods of Connecting External Devices bullet.gif Connecting to an Analog Line t_01522.jpg
(A) Telephone line (analog)
(A) Telephone or Answering machine
Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A) . The machine may not operate properly.
bullet.gif Connecting a Telephone or Answering Machine via a Computer t_01724.jpg
(A) Computer
(B) Telephone or Answering machine
sikaku.gif Methods of Connecting the Various Lines The following are some basic connection schemes that apply when you are connecting to a non-analog telephone line. These are examples and are not guaranteed to suit every connecting conditions. For details, refer to the instruction manual supplied with the network device (control devices such as an xDSL modem, terminal adapter, or dial-up router) you are connecting to this machine.
(A) Digital Subscriber Line
(B) Splitter
(C) xDSL modem (splitter may be built-in to the modem)
(D) Computer
bullet.gif Connecting to an ISDN Line For details on ISDN connection and settings, see the manuals supplied with your terminal adapter or dial-up router.
Please be informed that you can access Canon's online support site for your printer by clicking here. You can find many solutions to your problems by searching their database once you have navigated to the support page for your model.
I hope this information allows you to resolve this issue. If not, reply back with a comment to this thread.
If so, please take just a moment to rate this post. Thanks!
Apr 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannot send or recieve faxes
You cannot send a fax on a broadband connection, they should have given you a splitter, if not get one, the splitter is a small box like thing, it has two telephone sockets on one side and one socket on the other, the telephone line from the wall is connected on one side, on the other side you have to connect your adsl modem in one and your telephone in another socket, Usually the sockets have descriptions on them specifing which decive should be connected to the socket.
Now you should have a dial up modem(56Kbps internal or external modem) connect this modem to the socket which specifies, Telephone. Configure the modem. configure yor fax settings to use this modem. Now you can send your faxes.
If your ISP does not support dial-up then you cannot use it to send faxes.
Post back with your results.
Jan 04, 2008 | Computers & Internet
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
Intel Dot Station (INTC300AIO) PC Desktop Logo
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
