Question about Stamina Products Stamina 55-1610 Inmotion E1000 Elliptical Trainer
Broken belt on inmotion e1000 ellipitical
The drive belt is broken and needs to be fixed, how do I do this?
When i change my drive belt it gets shreded on start up
Sounds like either the belt is not tight or more likely your door balance is heavy ie fatigued/broken springs or its hung up somewhere.
Apr 16, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
Need to add another computer to my Linksys E1000 but lost the CD
You don't need the CD. Post the make, model of computer and the OS on it.
Dec 26, 2012 | Cisco Linksys Wirelessn Router Black...
Does the Nordic Track E7sv Front Drive Ellipitical have a quick start or manual option?
please see the instruction manual for this situation and follow the step>
go for free download : www. fitness.manualsonline.com or www.manualsfactory.com or www.iconservice.com
sincerely. God bless you
May 07, 2012 | Nordic Track Nt E7 Sv Front Drive Drive...
Need part for Mastercraft belt sander 54-7240-8 I need to replace the belt on the motor that drives the belt drive assembly. The motor runs ok but, the wheel that drives the sanding belt doesn't turn...
Anyone has a broken belt sander 54-7240-8 within Canada? I could use a particular part from it to fix mine. If you do, email me at mstevlik@zoznam.sk
Thanks.
Sep 27, 2011 | Tools & Hardware - Others
DC30 Denon cassette deck Drive belt broken Are spares available? Are there instruction on how to replace drive belts?
Hi J,
Sorry no solution for you. But I was wondering if you managed to fix yours. My D-C30 just has the same issue. 10 seconds of clicking and reading on another thread it sounds like the drive belt is broken and needs fixing.
Did you manage to find any instructions or spares etc to do this?
cheers
Nick
Mar 23, 2010 | Denon D-C30 Shelf System
My 97 dodge voguer belts don't spin but the car can still drive what is wrong?
Hi:
If your engine is running, but no belts are moving, you either have a belt broken, or the tensioner is broken. You need to have this fixed ASAP, as your vehicle wont have power steering or charging.
Dec 02, 2009 | 1997 Dodge Caravan
CD will not eject - it plays fine - but the tray will not open
If the tray mechanism is belt driven, the belt may have become loose or is broken and needs to be replaced (usually the belts are of a standard measure and can be purchased in electronic stores or via internet), but if there are only gears to drive the tray mechanism then it could be broken teeth on a gear wheel, faulty drive motor or faulty motor driver electronics.
Hope you can fix it.
Regards,
Triarcuate
Oct 17, 2009 | Denon DN-C615 CD Player
While running on the treadmill there is loud noise
Probablt don't need a new belt. You need to isolate noise. Listen and look for any signs of rubbing in the area that noise is comming from.
Jul 27, 2009 | Stamina Products InMotion Treadmill
Altec lansing inmotion IM7 how to fix dock door?
I've found a solution. Most likely you have broken the catch inside this part so it needs replacing but don't worry, it's relatively easy to do. The latch is the black piece of plastic behind the door with a claw sticking out.
1. First, email the manufacturer and and ask for a sample latch to be sent out to you. After a bit of research I finally found them. In the UK they make them in white so I ordered one of those as I think it looks better (part #DL1WH): http://www.richco-inc.com/component/jumi/search-parts.html?searchinit=true&searchtype=rohs&interest=DL-1&Submit3=Submit
2. Get a pair of thin pliers and carefully pull out the old latch. To do this pull on on any part of the outer rim. I used the lower edge. Don't worry of you damage it. You'll be throwing it away anyway. Just don't damage any of your speakers.
3. Slide the new latch into position and push into place.
4. That's it. All fixed!
May 14, 2009 | Altec Lansing inMotion iM7 (021986950806)...
Stamina Products Stamina 55-1610 Inmotion E1000 Elliptical Trainer Logo
23 people viewed this question
Top Stamina Products Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
Are you a Stamina Products Exercise and Fitnes Expert? Answer questions, earn points and help others
