Question about Dryers
Cant find numbers on hunter fan to sync with remote
Remote #85752-03 has numbers accessible but there are no numbers to match remote to fan
  • 323 Answers
SOURCE: Remote not working fan...
You can get them a Home Depot. You may have to buy the receiver and the remote together.
Posted on May 26, 2009
venexcsd
  • 1185 Answers
SOURCE: my light works works from the siwtch but my fan will not come on.
Have you changed the batteries?
If they are low on power you may get an Led to light up but not a strong enough signal to operate the fan
Posted on Jul 20, 2009
VtToolMan
  • 704 Answers
SOURCE: I need a hunter remote control unit part
This particular Hunter remote control unit has been known to have interference issues for some time now. It is very suceptible to picking up other transmissions, such as those from TV remotes, etc.
If you're having intermittent operation of the fan and/or light, you can try setting different codes for both the receiver and the remote.
That being said, the best source for a replacement unit is directly from Hunter, since you might also still be under warranty you might get it replaced for free, if you remembered to fill out and mail the warranty card!
Of course, if you just want to replace a lost or broken remote, give them a call and order one (or two and have a spare!).
To speak with a live Technical Support Representative call: 1-888-830-1326 (United States) 1-866-268-1936 (Canada) Hope you find this Very Helpful and best regards!
Posted on Aug 21, 2009
  • 3 Answers
SOURCE: Hunter Fan has stopped accepting remote control signals
I'll guess and say that the fan quit working properly shortly after either a power surge in your house of after a light burnt out after turning them on. It has happened several times to the two Hunter fans we have here, both with the wireless remote control. After having both replaced under warranty, and then paying for a replacement, I finally took the receiver apart and found the root cause. There is a power regulator (looks like a power transistor) that uses the aluminum portion on the housing as a heat sink. The part is easy to replace for those of you who are handy with a soldering pencil. For those of you who are not, I'm sure you know of someone who is. Now for the good and bad news. The good news? The replacement part is about a dollar from an electronics supply house called Mouser. I tried Radio Shack, but they have really cut back on electronic components. The bad news? I can't remember the part number. I have a spare one, but I can't find it right now. I will look for it and if need be, I'll open up the receiver and get the number off of it and post back to this thread. After replacing the part in both a little over six months ago, we have had no problems with the receivers. Voltage spikes no longer take out the regulator.
Posted on Jan 04, 2010
SOURCE: Hunter Fan problem
Thge black boxes are capacitors. One is a single and the other is a dual. Evidently the dual runs the two lower speeds and the single run the high speed.
You can test capacitors for basic operation with an analog voltmeter set to Ohms (Rx1 setting is best) by charging up the capacitor with the leadshooked up in one direction, and then reversing them to watch for the slight jump as the capacitor discharges back into the meter... note that this test only works with an analog meter and it must be set to ohms.
This is only a basic test for capacitors and will not indicate if it's withing specs, only that it basically works.
IMO, Hunter is known for having bad capacitors. I've just purchased two fans and already had to swap out the light kits, which contains the capacitors and switches, in one becuse of poor operation and excessive humming noise. since the other fans has the same componenets, other than being a different color, I also thought to try the light kit/capacitor assembly in the fan I've already installed before also installing the second fan.
Guess what, the other set of electircal components with the capacitors runs the fan slower and hums louder.
According to Hunter's web site, humming is a sign of poor engineering in ceiling fans (meaning a power hum rather than a hum from loose components) I agree and Lowes is about to get two Hunter fans back as my three cheapo fans that came with my house do not hum and also the one in my old house did not hum and moved more air.
Even the better capacitor set that I switched out still hums to some degree, so I'm climing Hunter's using **** components, probably becuse their chinese suppliers are screwing them and they're not bothering to keep up the quality control.
Posted on Jun 08, 2010
MY RECENTLY PURCHASED REMOTE DOES NOT FUNCTION COMPLETLY.FAN OPERATES (1) SPEED ONLY -HIGH
Check the model number and compare it to the original that should be listed in your users manual. If they don't match see if you can get the original on ebay from a vendor in China. Seach on ebay by model number.
Aug 03, 2015 | Hunter 52" Ceiling Fan With Light And...
How do I get the remote to work fan and light
There are dip switches in the fan and in the remote that need to be set to the same numbers. You can set them to whatever you want, as long as they match. If these numbers don't match it won't control your fan.
Here's a few lines from the user manual:
"IMPORTANT! Before installing this control, check the factory dip switch settings. Refer to Figure 1. Be sure the dip switch positions of the transmitter and the receiver match, or the ceiling fan will not function."
Here's a link to the PDF manual, which has an explanation and a figure in the middle of where you can locate these dip switches on the transmitter and the receiver both.
http://www.hunterfan.com/uploadedFiles/Support/Downloads/41316.pdf
Jun 24, 2014 | Hunter 27185 Remote Control
Hunter fan remote control 99600 not working
This must be a common problem, since I Googled the part number and it popped up before I completed the number. I am going to have to order a new remote, since I don't have a solder pen. Wish me luck.
Jun 22, 2012 | Hunter Dryers
Changing switch box to universal remote but the number of wires don't match switch out hunter model 85464 switch box for hunter universal remote model 27227 060 but the number of wires done match and odd...
Hi. Your best bet here it to call Hunter directly as they have people on hand with all of the schematics who will assist you.
888-830-1326
Monday – Friday 7am – 7pm CST
Saturday 8am – 5pm CST
J.
Jul 22, 2010 | Hunter 52" Ceiling Fan With Light And...
I installed a Hunter On"Off fan and light control model 27157 on a Hunter Augusta fan model 21338. I tested the remote control and the fan and light on, however, after a period of time, the fan turns on...
Most likely this is caused by radio interference from some other device nearby. Try changing the "channel" by changing the dip switches on both devices and make sure they match. :)
Mar 27, 2010 | Hunter 27185 Remote Control
Cant figure out default dip setting on hunter fan23534-001
Just match both the remote and the fan to the same switch setting. Unit if wired correctly should work. Check to make sure that the remote wiring is correct from the fan unit to the remote
Sep 13, 2009 | Dryers
Reprograming Ceiling fan remotes
You need to find the dip switches or jumper blocks on posts on the remote and on the fan. As for the receiver, usually they are in a separate unit that slides into the hanger bracket that attaches to the ceiling inside the decorative canopy cover, otherwise they should be visible if you are looking down onto the top of the motor without having to open any kind of access. And as for the remote, you should be able to access them through the battery compartment. just make sure the codes match.
Sep 05, 2009 | Hunter 52" Ceiling Fan With Light And...
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
I bought a house with hunter remote control 52" fans, and one doesn't work, I replaced the battery and still doesn't work. How can I verify the remote code is correct for this fan? The code on the fan is...
set the remote to match the fan code. be sure you have a good battery in the remote and in thereceiver which is in the dish at the ceiling holding the electrical wires
Jun 23, 2009 | Hunter 52" Ceiling Fan With Light And...
Fan and light control model 27157
yeah, if you take off the battery cover on your fan remote there should be something called a "dip switch". it wiil be numbered 1,2,3,4, just flip these switches up or down to match the receiver that will be located in the fan houseing or in the fan canopy.
Sep 19, 2008 | Hunter 27185 Remote Control
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
