Question about Pool & Spa
Setting the clock on the Ecco hot tub - Pool & Spa
What does error code -0.3 mean on an Aruba Hot tub
Don't think that's an error message? Could be letting you know heat is bypassed for Max setting?
Feb 11, 2015 | Qca Spas Majestic Series Aruba Xl Hot Tub
How do you set the timer on a 1996 hot tub? It has an old timer with things (prongs) that you have to push/pull?!
These types of timers were used and are still used for many different devices. The dial represents the clock and you pull or push for the hours you want the device to run during the 24 hour clock. For a hot tub you will want circulation for at least 4 - 6 hours a day. To circulate but also to maintain the heat. With a good hot tub cover and good insulation inside the tub your circulating time would be less and save you some money. Hope that helps. 6f0fd63b-b068-4b09-9479-fc1b67bc8e93.jpg 29c9802b-b80d-438e-9f6a-66c31c024fd8.jpg
Apr 04, 2014 | Washing Machines
How to set the clock on an ecco L460 hot tub
Hold filter button down until clock blinks. Use up or down arrows to change.
Mar 25, 2012 | Pool & Spa
HOT AND COLD REVERSED MOEN & ONE HANDLE TUB
This is a very simple fix. NOTE: This is for a Posi-temp model only!! First turn off the house water. Relieve the water pressure at a nearby sink. Then remove the handle from the faucet. Remove the black plastic piece, then the two white plastic pieces (these control how hot the water gets by controlling how far the handle turns), then the metal cover over the center piece of the valve. Once these are out of the way, there is a small metal clip that you can see that holds the cartridge in place sitting in a **** on the top of the center piece. Remove this carefully with a small straight edge screwdriver, taking care not to lose it. Then with a small pair of pliers, pulling on the center of the cartridge, pull straight out. Once the cartridge is completely out, turn it counter clock wise, 180 degrees and then reverse the process. The hot/cold will be in proper location now.
Now for an older style, simply take the handle off, turn the center portion of the cartridge 180 degrees counter clock wise and return the handle. Hot/cold will now be in their proper locations.
Good luck.
Aug 26, 2010 | Moen & One Handle Tub & Shower Faucet
I purchased a Catalina Hot Tub that has a KDC-MP228 installed. The radio works however the CD player does count, recognizing the disc however there is no audio coming from the pop up speakers located on...
It sounds like the stereo has got some faulty circuitry internally. You'll need to replace the unit to be able to listen to CDs in your hot tub. you may want to look into getting a marine radio as a replacement. I'm sure this will be more suited to this application and is probably the kind that should have come with the tub in the first place. I hope this helps and good luck!
Feb 17, 2010 | Kenwood KDC-MP228 CD Player
Pump is running ever 5 minutes. The heat in the
Sounds as if the 'mode' for the tub is set to sense the temperature of the water. see if there is a setting on the control box to a 'timed' setting for filtering and heating instead of controlled by the temperature setting. the problem is the the control box is away from the water and when it calls for heat it is because the water is cooler there than in the hot tub. so when it calls for heat and the water starts to circulate it gets the hot water from the body of the hot tub and then shut down because it senses the 'hot water'. make sense?
Feb 23, 2009 | Blue Wave Aruba 15' Round 54" Resin Pool...
My hot tub won't turn off. I turn the pool on and
check the owners manual. I believe your are experiencing the auto set feature, default perhaps and see if there is a setting to change the auto switching. The older models used to do that all the time.
Feb 19, 2009 | Jandy AQUALINK RS TELELINK KIT
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
