Question about Proform XP 580 Trainer Treadmill
Proform 595LE Treadmill incline will not raise, motor will not start and you cannot calibrate it.
erpaalai
  • 999 Answers
SOURCE: My Proform treadmill will not incline. It is stuck
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Posted on Jun 17, 2009
maxtreadmill
  • 832 Answers
SOURCE: Treadmill will not level out and motor sounds all the time
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Posted on Jun 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: The incline on my proform treadmill is not working
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or
thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4.
If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced. It is possible the console is not giving the proper signal but we've never seen it happen in thousands of treadmills.
Posted on Jul 19, 2010
2manyhobbies
  • 128 Answers
SOURCE: my proform tl 585 is
Take the cover off and inspect the wiring. Make sure all the wires from the incline motor are connected.
If all the wires are connected and everything looks OK, try the incline again.
There are only 3 wires on the incline motor, red, white and black. This machine does not rely on any electronics to operate the incline. We know the motor works, because it will go up..Likely the switch in the console is defective.
To lower the incline, reverse the black and red wires, that will make up go down and vice versa.. If that doesn't work, the motor is likely defective.
The incline motor is available, around $110. To order find the model number on the frame of the treadmill and call the service number found there. Have your model number ready (starts with "P").
The console is no longer available.
Posted on Feb 27, 2011
ercupa190
  • 12223 Answers
SOURCE: My Proform 380 treadmill will
ADJUST 1) Reed swithc and optic disk.11_15_2011_9_21_16_am.gifIf after you did these adjustments Not work, replace the sensors.11_15_2011_9_21_36_am.gif
Posted on Nov 15, 2011
Proform 1450 treadmill incline problems
try to calibrate incline. For that check the video
https://www.youtube.com/watch?v=uz1cMWei7AQ
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 12, 2016 | Proform Pro-Form Performance 1450
My treadmill won't go down the platform how to lower it please help
If it is stuck in the incline position all you need to do is re-calibrate most of the time
The first step to re-calibrate the incline. ProForm provides calibration instructions in the treadmill owner's manual.
Hold down the "Stop" button and the "Speed" up button. Insert the safety key into the console then release the "Stop" and "Speed" buttons.
Press the "Stop" button then press either the "Incline" up or down button. Wait while the treadmill raises then lowers the incline ramp. Press the "Stop" button and remove the safety key.
Hope this helps or solves the problem, if you have any further questions please do not hesitate to contact us at 888-713-2880 or visit us online at
http://www.sportsmith.net/supportsearch.aspx
May 18, 2015 | Proform 1050T Treadmill
Incline problem
All icon models are the same. The easiest way to incline calibration is to start the treadmill, push the incline up button and then after you release the button, remove the safety key. Replace the safety key and the treadmill should calibrate.
If that doesn't work, press the stop and speed up buttons and hold, then place the safety key in place. This will bring you to the speed/incline calibration. Press stop again. now press incline up. This will run the incline calibration.
You may need to remove the hood and manually with a drill lower the motor. Using a slot screwdriver bit, lower the motor a bout 50 turns and then try the procedure above again if necessary.
Mar 05, 2014 | Proform Exercise & Fitness
How to recalibate a pro-form 595LE treatmill.
follow this steps and fix it. God bless you
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Dec 09, 2013 | Proform 595LE Treadmill Walking Belt
Proform crosswalk 397 will not incline
see the diagram, and RUN the software calibration for diagnose and troubleshooting.
lube the gear and racking from elevation motor, clean, and tigh any wires connectors:
Jun 29, 2012 | Proform Crosswalk 397 Treadmill
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
Proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
May 16, 2012 | Proform 860 Competitor Treadmill
Convert from KPH to MPH
You need to go into the calibrate routine. If it doesn't cover it in your user manual, remove the motor cover and check for a spec sheet. The spec sheet will detail the entire calibration process, including changing kph to mph.
Oct 26, 2010 | Proform 595LE Treadmill Walking Belt
The incline on my proform treadmill is not working and now I can't get the treadmill to start, it just keeps inclining up and down
4.
Jul 09, 2010 | Proform 650 Crosstrainer Treadmill
My Proform treadmill will not incline. It is stuck at about mid incline. When I turn on the treadmill, it raises and lowers back to mid incline right away. Despite pressing incline buttons, there is no...
Jun 17, 2009 | Proform Sport 1000 Folding Treadmill...
Proform XP 580 Trainer Treadmill Logo
48 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
