Question about GPX S7799 Shelf System
Turntable belt diagram - GPX S7799 Shelf System
Need a diagram of the belt configuration
Check out YouTube there are some standard videos on belt replacement that might apply to your model.
Oct 14, 2015 | Teac P-A688 Turntable
I need a diagram to re-install belt on Sony turntable PS-LX250H
I'm sorry for the difficulties you're experiencing in installing the drive belt. Please click hear to get the instructions to install a drive belt. Please click on the sub links on the page to view the diagrams.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 01, 2011 | Sony PS-LX250H Turntable
My Pioneer PL-112D turntable has a broken drivebelt, is it possible to buy a new one, and is there a diagram showing the belt "routing". Thanks.
I don't believe this belt is being provided by the Pioneer. So I did find another option at a reasonable price on E-bay.
http://cgi.ebay.com.sg/TURNTABLE-DRIVE-BELT-FITS-PIONEER-PL-12D-PL-112D-/290432607483
Jan 17, 2011 | Pioneer Audio Players & Recorders
Where can I find a diagram for belt routing on a PL-990 turntable>
no diagram needed...flip the table over, wrap the belt around the inner track then put the table back on, spin the table until the access cut is over the motor then stretch the belt over the back of the motors post and you are done.cheers.
Apr 17, 2010 | Pioneer PL-990 Turntable
Belt came off spindles
it's simple the belt goes around the platter and the motor spindle thats it!
Apr 25, 2009 | Sony PS-LX250H Turntable
Record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Apr 13, 2008 | Technics SL-1200MK2 Turntable
Pioneer pl 990
Remove any tape from the belt
That is the drive belt for the turntable .
It's not that hard to set up. Take the mat off the platter and wrap the belt around the underneath -slightly-less-diameter portion.
With a pointed end needle or something like it , put the tip between the belt and the platter portion it's wrapped against.
Pull the belt away from that( keeping the rest of the belt on the platter portion) and set it over the motor pulley. This is usually a small diameter brass spindle unit
Mar 27, 2008 | Pioneer PL-990 Turntable
Turntable drive belt replacement
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Nov 27, 2007 | GPX S7799 Shelf System
Belt Drive
The belt is replaced as in the following diagram from the manual that you can download on the link below: http://www.lpgear.com/at_pl50_om.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Audio Technica AT-PL50 Turntable
GPX S7799 Shelf System Logo
29 people viewed this question
Top GPX Audio Players & Recorders Experts
Tequella Chapman
Level 1 Expert
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
