Question about Supra 001004 Push Button Lock Box Key Safe
Combination i put in no longer works with code i put in and cant get opened
I have a new Logitech K520 cordless keybord/mouse combination. I use it for 2 pc's (1 Xp en 1 windows 7) by splitting it with a ATEN switch KVM CS-12. With my old Logitech combination S520 the switch...
Its all in the updated drivers, however the one OS "XP" may not have drivers available any longer. Remember XP is no longer supported and thus no one wants to write code for hardware being used with XP operating systems.
Feb 06, 2018 | Logitech Computers & Internet
Opens with out a code and can not get it to stop pulling the latch back. i tryed to put a new code in but cant grt past step 2
I THINK that the problem you describe is because the lock is in "Zero Code":
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE."
Go to this web page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
and position your mouse on PDF under the "TIPS" (rightmost) column on the grid line for the L1000.
Two choices will pop up; click on the upper one "Changing the code/Combination...." and download and open this file.
If it does not open, you need to download and install Adobe Acrobat on your computer from here: http://get.adobe.com/reader/ It's free!
When you get this document open, you will see the statement that I quoted from the top about the Zero Code. At the bottom of the document you will see:
Troubleshooting
Symptom/problem: Outside knob/lever when turned always retracts latch without depressing
any buttons.
Cause: Lock is in zero combination.
Solution: Follow the procedure for changing a combination except omit step 3 (do not enter
the existing combination).
One last nasty piece of information: If you don't have the necessary DF-59 Key or spanner wrench mentioned in the procedure, you can get either from these sources:
Key:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Whew! That was a lot of stuff, to digest, so I hope it helps. Good Luck!
Jul 14, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Locked ipod cant remember combination
"Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize."
Cite: http://www.everymac.com/systems/apple/consumer_electronics/ipod_faq/ipod-reset-code-to-unlock-screen.html
May 30, 2009 | Apple 160 GB iPod Classic (Silver) +...
I have a VIP suitcase with three digit combination lock. Thouh I have not changed the code, it is not opening. It seems to have stuck. I have tried to open it even with a few earlier combinations or my...
I just opened mine. I also knew the the password and the suitcase wasn't unlocking. If you are all sure that u know the password. Then put some oil in the lock. wait for 1 hour... This will help. If it doesn't work then.. Put the lock code and push the clips manually with a pait or scissors or a small blunt knife.. Don't worry the lock is just stuck. After all it's a vip and not samsonite
Mar 21, 2009 | Baby Gear
How do I change an electronic safe combination?
hi, on mine if you open the door their is a red button press and hold for five seconds, then release put new code in then press again for 5 secs turn thelock to lock position do not close the door, put in the new code and see if it ulocks, if so, bingo, DO NOT CLOSE THE DOOR TILL YOU ARE CERTAIN THE CODE YOU PUT IN WORKS, hope this helps, mine only has a four digit code but i think its the same set up.
Feb 18, 2009 | Schylling Combination Steel Safe
Changed the batteries......now can't get it to work.
if you cant even put the batteries in, how am i going to teach you to code it? there is diagram in side case showing PLUS up or down, follow it. both go in same way, why would you put neg to neg. do yu do that with flashlight batteries. come on.
Jan 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can't seem to unlock my safe Sentry 1250.
Locksmiths agree sometimes even with the green light the safe’s batteries are not strong enough to retract the latch. Try replacing them with some new alkaline batteries
Jul 13, 2008 | Sentry Fireproof Safe
Supra 001004 Push Button Lock Box Key Safe Logo
41 people viewed this question
Top Supra Home Security Experts
Lawrence Oravetz
Are you a Supra Home Security Expert? Answer questions, earn points and help others
