Question about Dishwashers
Dishwasher gld4560n10ss The circulation pump is hanging up. I can give the motor a spin and it works fine until the next cycle. Is there a starter solenoid that has gone out or do you think there is a flat spot on the motor?
catriver
  • 878 Answers
SOURCE: dishwasher drain solenoid
Snoopy, first of all you did a good thing when you ordered the timer. I have got stung on this model by just changing the solenoid. The fact is the timer is stalling and sending too much voltage to the solenoid and burning it up. Just order the new solenoid and install it. The solenoid is a AC circuit so it doesn't matter which way the harness is on, you should be just fine with the new timer..Catriver..post back.
Posted on Mar 05, 2007
  • 59 Answers
SOURCE: Dishwasher not filling
There is a new part that replaces the Overfill Pressure Switch part number 8058474. It is now part number 8071024 available from ASKO part sellers. The hose inlet on the new part has what looks like a blockage. It actually "dampens" the effect of the pressure sent through the small hose attached. The old part does not have this "damper" This pressure switch works in conjunction with the flood protection switch in the bottom pan of the dishwasher.
See my rant at
http://www.fixya.com/support/t216284-asko_dishwasher_1475_indicates_high
Posted on Feb 18, 2008
SOURCE: Dishwasher does not circulate water
I had a similar issue and it was the Motor Circulation Pump. Part #239144 @ Marcone Appliance Parts Center (860) 548-0080
Posted on Mar 03, 2009
localwonder
  • 6784 Answers
SOURCE: No water coming into dishwasher
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Posted on Jun 06, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 06, 2013 | Dishwashers
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
I have a kitchen aid dishwasher KuDR01TJBLO noisy when draining
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 28, 2012 | KitchenAid Dishwashers
We use the Cascade tablets but they don't dissolve
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Apr 13, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen aid dishwasher
Either:
Good luck,
Vlad
Sep 01, 2008 | KitchenAid KUDMO1FK - Multiple Color...
Bosch shu5315 06
it sounds as though the circulating pump may not be operating. if so fault is often due to the pump capacitor being faulty and this is a cheap part.
Jun 05, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasherwont wash
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Sep 04, 2007 | GE 24 in. GSD2120C Built-in Dishwasher
Dish washer
Aug 30, 2007 | Dishwashers
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
Owen Barnes
