Question about Panasonic TX-32PK1 TV
Aspect ratio makes no difference
My screen is actually a TX-28PK3L. i can change aspect seemingly well, but its stopped allowing me to see the whole picture, as text or titles in programs or movies are just off the screen. Before changing aspect brought these back into the picture, now it doesnt do a thing. any idea?
  • niemand Oct 08, 2007
    theres no option for that unfortunately... :(
    Genius:
  • 1,153 Answers
Can you go into menu and turn off autoformat?
Posted on Oct 08, 2007
  • Lashawn Robinson Oct 08, 2007
    Its the same as the aspect ratio 4:3 16:9 etc!
SOURCE:
I cant get picture to fit screen. like when news is on the words on the bottom dont fit
Sounds like the picture is Zoomed. Note it. Refer its user manual to get details to make it to Normal state. Electro help
Feb 18, 2015 | Televison & Video
Tip
Projection Screen Tip #2
Make sure that the screen is the correct aspect ratio for the most commonly used projection device. For instance, a video projector should be in 4:3 or 16:9 modes, depending on its native aspect ratio. The screen should match the aspect ratio that is used most often. This will allow the entire screen-viewing area to be filled by the projected image.
on Aug 16, 2010 | Office Equipment & Supplies
How do you set cable to 16:9 output?
Different channels are broadcast in different aspect ratios, depending on the network and the show(s) being broadcast. Many older show are still broadcast in the 4:3 ratio to avoid distortion. Currently, there is nothing in the broadcast signal that tells the TV what aspect ratio to use. Therefore, TV remotes have a selection button (mine says "P.SIZE") that allows the user to change the aspect ratio to optimize the viewing experience.
Sep 05, 2014 | Hitachi Televison & Video
Picture size on panasonic txl32 tv
Change the aspect ratio on the remote. If this does not fix, change the aspect ratio on your cable or sat box.
Apr 10, 2012 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
2 vertical bars on the right side of screen, thay are black, has picture and sound but no thing in the bars
That's because your aspect ratio is 4:3. To get the picture to fill the whole screen change the aspect ratio to 16:9. You can do this by pressing the aspect button on the remote (right above the channel + button) and changing it to different sizes such as cinema, panorama, and full. Try all the options and see which one like best.
May 26, 2011 | JVC PD-42V485 42 in. EDTV-Ready Plasma...
How can I make the picture size fit the screen? I loose picture around the edges. Seems like it is displaying at a larger size
The issue your having is aspect ratio. Some programs and commercials are broadcasting in a higher resolution so some fill the screen and some have black bars top and bottom. I suggest searching "aspect ratio for video". It would take me all night to type it out. But you need to know how the different resolutions change the size of your image. Also in the TV's menu you should see an aspect ratio option. Try the different settings to see if you can find the best.
Aug 19, 2009 | Zenith A25A23W 25" TV
Picture does not fit screen
make sure you cable set top box is set to proper aspect ratio should be 1080i
Mar 23, 2009 | Panasonic (TH-50PZ700U) Television
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
Panasonic TX-32PK1 TV Logo
113 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
