Question about Saeco Easy Espresso Machine
Saeco easy won't brew - Saeco Easy Espresso Machine
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Brew light blinking
It is telling you that the temp on the machine is too low. It is possible that one of the thermostats on the boiler is damaged.
Posted on Sep 17, 2009
  • 18 Answers
SOURCE: cannot release the brew group for, saeco
Group is stuck in mid cycle due to some obstruction. You will need to have it serviced. Though it's possible to jiggle and pull it out. The machine will not likely reset itself, preventing you from re-inserting the group. Still requires a service to manually remove obstruction and reset it.
Posted on Feb 10, 2010
Saeco Vienna superautomatica won't dump grounds puck into dump box
This needs looking at by a Saeco repair shop - the brew unit travels in a distinct 'pathway' from being empty, to filled, to coffee being tamped, then to being emptied. Yours is obviously not working as intended.
It may be the brew unit needs lubricating ( NOT OIL) or it may be the gear system that drives the brew units movements that needs attention.
Cheers
Mike.
Nov 14, 2017 | Saeco Vienna SuperAutomatica Coffee...
The steam light on my Saeco Aroma does not turn on (and no steam comes out), even after the brew light turns on and I press the steam button. How can I get my steam to work?
HI
It is probably your steam thermostat that needs to be replaced. There are 2 thermostats. The Brew and steam. If one of them fail it won't heat the boiler for that mode. They are easy to replace.
Oct 05, 2010 | Saeco Aroma Espresso Machine
Diagnostics for saeco Easy
theres a micro switch that gets tripped when theres enough coffee which activateds the dump selinoid
Nov 18, 2009 | Saeco Easy Espresso Machine
Brew light blinking
Sep 13, 2009 | Saeco Vienna Espresso Machine
My Saeco Easy superautomatic machine will not finish the brew cycle. It gridns, tamps, and does not pump water. It dumps dry grounds into the dregs container. I have descaled the machine and lubricated the...
maybe your valve dont open water or your brew unit plugged out.unscrewed two screw on top brew unit and you will see sprin and small plastic ball ,clean inside and try
Aug 22, 2009 | Saeco Easy Espresso Machine
Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Jun 03, 2009 | Saeco Easy Espresso Machine
Saeco italia has front red light explanation
This red light is to indicate if the water tank needs filling, if the bean hopper needs filling, or if the brew unit is not in the unit (after cleaning) or not in the correct position.
Dec 28, 2008 | Saeco Easy Espresso Machine
Saeco Easy dispenses first, then grinds
I think you have pre-brewing on your machine, if you have a Sirius then you have these settings in the menu under coffee settings.
I don´t think this is on Saeco Easy, only if you will make two cup of coffee, then the machine will pre-grind the beans for the second cup.
/Mirran
Aug 23, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Cannot operate the machine
You can take out brewing unit and when it out you can see a hole in the chassis, that pin you see in the hole is the problem, take it out and clean it. If this problems comes back you have to take it to a Saeco service center
Mar 27, 2008 | Saeco Easy Espresso Machine
Saeco Easy Espresso Machine Logo
37 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
