Question about Dualit Kitchen Appliances - Others
How do you replace the element on a dualit architect toaster?
Replace element on Architect
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
  • 37 Answers
SOURCE: Dualit 4-slice toaster (84US) warms only slightly
please check and make sure the red button in front is pressed to the right so that all 4 slots will heat up.
if it is to the left, only the left 2 will heat up.
if you need additional help contact the service center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Posted on Nov 20, 2008
juliant61
SOURCE: Dualit combi heating element 12/95
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
Posted on Nov 30, 2008
cactus bob
  • 267 Answers
SOURCE: Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 04, 2009
espressonist
  • 1711 Answers
SOURCE: dualit toaster 3 slot- how
We have the procedure here in this link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Good luck
Posted on Aug 20, 2010
Kitchenaid Architect toaster - one of the bays not functioning
If only one bay is not working it is more than likely the element has burnt out. Can you see a break in the element wire? If so a new element can be purchased. If you are not confident your local repair guy can help you out
Apr 21, 2013 | Kitchen Appliances - Others
Where can I get the parts for my dualit toaster
You can buy the heating elements and or the timer from ebay, they are in very good price. They have also instruction on how to replace the elements and we have also one link that is helpfull.
Dec 07, 2011 | Dualit 40352 4Slice Toaster
Dualit Toaster trips RCD on consumer unit as soon as the timer switch is turned
One of elements, or one of the wires have be cut and is touching the metallic body so you need to replace the element or wire
Mar 09, 2011 | Dualit 20084 2Slice Toaster
I changed the element in my Dualit toaster; still doesn't work
If I understand well the blackened wire is an overheated wire which it is probably but off in one point so no electricity comes to the element anymore.
However overheated wire in you metalic toaster is a very danger thing to have and need to replace all the wires you have noticed that they changed color or not look good contition.
The problem have been caused from a problematic element which is the one you have already replaced.
However you if after you replace the wires you need to inspect the toaster after some time in order to be sure that not any other element causing the problem.
Good luck.
Mar 05, 2010 | Dualit 20247 2-Slice Toaster
Dualit toaster - timer sticking.
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
Feb 22, 2010 | Dualit Vario 3 Slices Toaster
Where do I buy replacement elements from for Dualit toaster, the middle one has died? I last bought one from a shop in Puckle St Moonee Ponds and it has closed down.
Try ebay, their good price and they will come to you fast and on low cost. The midle one is called "CENTER" and the one at the two ends called "END"
Good Luck
Feb 05, 2010 | Dualit Vario 2 Slices Toaster
Out Dualit toaster keeps blowing the fuse. It's
Probably one wire Loosen up or a wire from one heating element have cut off and is contacting the metal body of the toaster. You need a good visual insect of your toaster, you may use a flush light to see inside the electriacl elents and also open the bottom base to insect the wire conections to the heating element.
I beleive one or more heating elements is the problem and you need to replace them.
Good Luck
Feb 01, 2010 | Dualit CTS4E 4-Slice Toaster
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Replacing the elements on a Dualit 2-slice
You can find out how to replace the heat elements and purchase replacements at the Dualit Repair Center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Nov 05, 2007 | Dualit 20247 2-Slice Toaster
Kitchen Appliances - Others Logo
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
