Question about Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile Transceiver Amateur Ham Radi
How do I set the roger beep on a yaesu ft 2900r
2 Suggested Answers
  • 211 Answers
SOURCE: yaesu ft 1500 m
Here you can see the schematics http://www.repeater-builder.com/yaesu-vertex-standard/ft-1500/ft-1500m-sch.pdf
The manual can be found on the Yaesu website, http://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=106&encProdID=92FB2363C1E0B9EBC9D3479054E0120B&DivisionID=65&isArchived=1
Good luck,
Gerard
Posted on Jan 30, 2010
Ft 2900r when I push then talk button on mic it shows error on all channels even with second mic
Sounds like a programming error. Does it work properly in VFO mode? Did you try a reset?
Jan 10, 2015 | Yaesu Ft 2900r Vhf Mobile 75 W Two Way...
WILL NOT POWER UP
How is the radio power connected? directly to the battery? or thru some accessory connection....... it should go directly to the battery with fuses on both leads. If there was not fuses on both wires, I suspect you have a serious problem caused by the "jump". However, if there are fuses on both, check them with a ohm meter and tell us the status. 73, Jim - K9KUZ and what is your call sign?
Apr 22, 2014 | Yaesu Ft 2900r Vhf Mobile 75 W Two Way...
I have a yaesu ft2900 ham radio when i key the mic it turns off then comes back on help
You have all the making of not enough power to operate the radio and it shuts down to protect itself. Hook the power leads directly to the battery terminals and keep the leads as short as possible. The more wire you have the more resistance and the more resistance the less volts your radio can see. Also be certain you have a good ground connection
Apr 15, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
How to turn beep off when transmitting
all the beep is for is so people can tell when you are done transmitting. There should be a push knob or button or just a plain old knob that has R.B. printed next to it . Turn it off.
Apr 12, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Eeprom error ? B0003 on display
if a reset has failed, these means either the eprom or the cpu is damaged.
Feb 11, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Software Menu Aligment yaesu FT-857
http://www.hampedia.net/yaesu/ft-857-second-menu.php this link lists the settings to put back to factory abc together when switching on to access
Apr 10, 2013 | Yaesu FT-857D HF/VHF/UHF Mobile...
Ft 2900r yaesu all i see on the screen is B0001 i can't see the frequency
Try powering the unit up while holding the Set/MHz button. I did that and it restored the display (and the rest of the radio's operation) back to normal.
The character codes are test-mode displays that correspond to frequencies (in MHz):
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
I haven't the foggiest idea why this isn't in the manual somewhere, or at least flipped back to normal by a two-key or three-key reset. 73, k2mct
Sep 16, 2012 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile Transceiver Amateur Ham Radi Logo
304 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
