There is a simple way to find out which speaker is which. It takes a few minutes to do, but all you have to do is is use your balance and fade adjustments to isolate one speaker at a time. Then hook up your different wires from your original wiring harness one set at a time until you find the speaker which coinsides with the one you have isolated on the deck. repeat this with each different speaker.....right front, left front, right rear, left rear.
Did the xplod deck work correctly before you installed it? When it cuts out does it loose all its memory and setting and go back to factory defaults? It is possible that the deck is faulty.
From autozone.com. Please let me know if you have any questions.
yea a amp 2
