Question about Sanyo KHS3672R Indoor Wall Mounted Air Conditioner
Heat pump error code - Sanyo KHS3672R Indoor Wall Mounted Air Conditioner
American standard error code 158
thermostat error codes for an american standard ... - AllExperts
en.allexperts.com > ... > Heating, Air Conditioning, Fridge, HVAC
Aug 22, 2010 - programmable thermostat, error codes, american standard: James, I am not familiar with that stat set up,short of goggle/yahoo the codes may ...
Jul 24, 2015 | American Standard 5000 Heat Pump Unit
Have an lg dfs unit not working cooling lamp flashes 7 times heat lamp 6 times what is the problem?
DEFINING COMMON ERROR CODES www.lg-dfs.com/.../dfs-tp-ag-002-us_012h29_lgtechpaper_errorcodes-la... Aug 29, 2012 - Refer to Service Manuals posted on www.lg-dfs.com to troubleshoot individual error codes. Error. Code. Description. No. of Times Indoor Unit ...
Mar 02, 2015 | LG LSN121HSV LSU121HSV 1 Art Cool Ductless...
How to fix Fujitsu a1 error code for 15rls2 heat pump.
Try cutting power to the indoor and outdoor units for a couple of minutes. Restore power and see if the error returns. The A1 error for this line of units indicates high compressor discharge temperature, which translates to overheating outdoor unit.
If this error code remains after a hard power reset, it's time to pick up the phone. Either you have a refrigerant leak which has resulted in a loss of freon, or a blockage in the refrigerant plumbing that is backing up pressure in the system. Both conditions will require a major repair by an authorized service tech to get your heat pump up and running again. 25361378-awph1b3yhxdrnyqdcrsrelkr-4-0.jpg
Please mark my answer as helpful.
Jan 09, 2015 | Fujitsu 15RLS2 Halcyon Wall Heat Pump Air...
How do i fix the firefly heat pump geyser error code a
There are two (2) ways to fix Firefly Heat Pumps Error Codes Error: Advanced Computer User Solution (manual update): 1) Start your computer and log on as an administrator. 2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore. 3) In the new window, select "Restore my computer to an earlier time" option and then click Next. 4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next. 5) Click Next on the confirmation window. 6) Restarts the computer when the restoration is finished.
Apr 28, 2014 | Pool & Spa
Error code 67?
The indoor fan motor had blocked.
Feb 05, 2014 | LG LSN121HSV2 11,200 BTU 20 SEER Ductless...
Error code 82
SOUNDS LIKE A BAD MOTOR.
Oct 25, 2013 | Carrier Heating & Cooling
I have a Aqua Pro heat pump P130 with error code F5 does anyone know what that means
Error FS?
Unit has started defrost cycle and will reverse operation in 5 minutes.
If coolant has nor res=ached desired temp, unit will shut down and display FS
Other models:
FS can mean not enough water flow in cooling mode.
Mar 25, 2013 | Aqua Pro Swimming Pool Heat Pump 125000...
Heat pump?
There could be several issues at work here.
  • First, is the heat indicator light showing on the topside?
  • Is the pump running but temp is not rising?
  • Any error codes displayed on the topside panel?
The drop in water temperature could be caused by a faulty temp sensor or faulty high limit sensor.
Check those items out and see what you come up with.
Rod
US Parts Center
888-521-6183
Mar 14, 2013 | Pool & Spa
Sanyo KHS3672R Indoor Wall Mounted Air Conditioner Logo
42 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
