Alba pin reset - Televison & Video
How to change pin no. for forgotten pin no.for Alba phone
Hi, To hard reset Alba Phone
If you've forgotten your pattern code The link below is a youtube video of a guy shows 3 way but the 3rd way is a factory reset meaning you loose every thing in your phone
but the first two ways are worth watching.
I hope this helps.
Dave
https://youtu.be/dmBqvh1UUD4
Feb 05, 2018 | Cell Phones
Alba dvd1006 stuck on standby
Try a hard reset first. If it do not help you, the main board to this set is faulty and should be replaced. To make it a hard reset, unplug it from AC mains wall socket, and reinsert after an hour or so. Then check. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
Jan 08, 2017 | Alba Televison & Video
Reset code on alba tv so it will let me retune the channels
menu, go down to features but not actually into features, then 4, 7, 2, 5, green.
Jan 04, 2015 | Alba Televison & Video
How do i reset my pin code so i can retune my alba tv
menu, go down to features but not actually into features, then 4, 7, 2, 5, green. you have to do it quite quickly
or just menu 4725
HOW DO I RESET AN ALBA ALDTR160 TO FACTORY SETTINGS
You have to enter its service mode to do this. Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 18, 2014 | Televison & Video
Forgot pin code for grundig gud300hd freeview hd box
Ok this info does not seem to be anywhere so here goes.....
Grundig gud300hd and others of same build alba ect...... set top box pin reset
UNLOCK CODE1. Press MENU and go to Settings and press OK.
2. Go to Parental Control and press OK. The 'Enter the PIN Code' menu will be displayed.
3. Press i (information) button once then enter 4000.
4. Go to Change PIN Code and press OK.
5. Press i (information) button once then enter 4000.
6. When it prompts for New PIN enter the desired PIN number using 0~9 keys. Enter it again to confirm.
hope it helps
Nov 24, 2012 | Grundig Televison & Video
I set a parental control password on my alba lcd32880hdf 2 years ago and can't remember what it is. Can I reset it?
When you said this: They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!, is that dvd on the tv or a normal dvd player
Jan 01, 2012 | Alba XJR 1300 SP Televison & Video
Alba hd set top box pin code
Most of the ALBA equipment uses a default of 8's, and some people have reported that 1's are their default code.
I have an STB300HD that's just been brought to me for checking, the default code for that model is 8888.
Another one I had looked at/repaired last month, i cant remember the model but it was still an ALBA, had 888888 as its code.
As far as I am aware, you can type the wrong code as many times as you like, i'd tried over 10 codes on the STB300HD before finding the correct one and it never gave any warnings or total lock-outs. :)
Good luck.
(just to help in Google searches for others owners).......
ALBA STB300HD parental lock default code = 8 8 8 8
Sep 07, 2011 | Televison & Video
How to set up cctv camera video output to Alba 19880HDF via vga input
vga input is a 15 pin D shape connector. find vga out put in your cctv camera. note that cctv camera's vga out & Alba's vga input are male or female connectors. get the appropiate vga cable & connect to input & output.
Aug 24, 2011 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
