Question about Precor 932i Treadmill
Blinking "Stop Key" and wont let me start a work out
Thieft light wont stop blinking
Usually means you have tried to start the car with a key that the computer does not recognize, or the chip in the key has failed.
Feb 16, 2015 | 1997 Ford Taurus
Anti theft light blinking,dash lights up,windows roll up and down but car wont start. How do I start it?
If the anti theft light is blinking and you say that everything else fine.. My first thought is that the key is not programmed to the vehicle. The key has a internal chip that must be programmed to vehicle in order to start. Now my other question is, Is the key your using for the vehicle the original key or have you just recently had a key made? Regardless, in order for the yur Tribute to start, the key. Or keys have to be program to vehicle by your neighbor dealership. Thats the reason for your anti theft light is blinking
Oct 09, 2014 | 2001 Mazda Tribute
My 1999 aruora secrity light is blinking and my car wont start. If it does it only runs for bout 3 sec then dies again . Thats only when its been sitting for a couple day . Nobofy can figure out whats...
Sounds like a problem with the security. It immobilizes the fuel injector circuit when the security is on.
Try this: turn key to on, and wait several minutes (up to 30 minutes) to see if light stops blinking. If it does stop, turn key back off, then try to start it. If the security light goes off, it may have reset. If it does not stop blinking or staying on steady, the dealer will charge outrageous prices to fix it-possibly over $800. Google "passlock bypass" or "passkey bypass" or "VATS bypass" to see your options. A site called newrockies sells a module (about $200) that forever bypasses the whole security system.
Oct 01, 2014 | 1999 Oldsmobile Aurora
Light wont stop flashing
Light flasher will not stop flashing.
Jan 13, 2014 | RCA Televison & Video
Security light was on then drove next time off. now car wont turn over to start
If your security light is blinking.Turn key to on position(2 clicks) wait for 10 minutes security light should stop blinking.Turn key to off position. Turn key forward 2 clicks wait for 5 seconds and try to restart the car.
Aug 29, 2013 | 2001 Pontiac Grand Am SE
My alarm disabled my car and the car wont start how do i disable it
Turn the key to the start position, but dont start. Wait for lights to stop blinking and push the brake pedal down a few times, light should flash again, turn ignition to off and remove key, exit car and lock doors, use key to open door and then try to start it. Good luck.
Feb 26, 2011 | Oldsmobile Cutlass Supreme Cars & Trucks
Starter ok no blown fuse. all lights working but it wont start. anti theft light blinking fast os soon as you turn it to on. what is the problem.
it is the microchip on your key.. you have to reset the key by sticking it into your ignition and turn it to the run position for 5 mins. at this time the light should stop blinking then turn your key to the off position for 1 sec. repeat six times then your last attempt the car would start guarantee.... notice: as you turn the key to run position the light would blink rapidly for 5mins.. right when it stops turn to the off position for 1 sec.. remember six times..
Feb 01, 2011 | 2004 Ford Explorer
The car wont start, the brake pedal is locked like the anti-theft is active, the anti theft light is flashing when the keys are in the ignition. when i try to turn it on it doesnt turn over, just makes...
TRY REPROGRAM KEY .PUT KEY IN IGNITION SWITCH TURN IGNITION SWITCH ON POSITION 20 SECONDS DONT START ENGINE WAIT 20 SECONDS TURN OFF SWITCH THEN TURN SWITCH BACK ON 20 SECONDS WATCH THE THEFT SECURITY LIGHT BLINKING.WHEN THEFT STOP BLINKING VECHICLE WILL CRANK.IF LIGHT STILL BLINKING.TRY FEW MORE TIMES KEY IN SWITCH ON POSITION FOR 20 SECONDS.MAKE SURE YOU HAVE THE CORRECT CAR KEYS IN SWITCH IF NOT WRONG SET OF CAR KEYS WILL SET OFF THEFT SECURITY SYSTEM.IF KEY RESETTING TRICK DONT WORK.CHECK BATTERY POWER MAKE SURE YOUR BATTERY HAS 12.5 VOLTS AND CHECK SECURITY THEFT FUSE.IF ALL LOOKS GOOD YOUR SECURITY HAS TO BE CHECKED OUT AT THE DEALERSHIP.
Oct 08, 2010 | 2006 Ford Fusion
Wont start, security light keeps blinking
Turn the ignition switch to the on position and let the light blink. It should stop in about 10-20 minutes. then you can start the engine. if the light does not stop blinking likely the key switch is bad or, (less likely the module). Make sure your battery is in good condition when doing this or it wii kill the battery before the coding is complete (use a jumper to a good battery if necessary but don't turn the other vehicle on)
Oct 13, 2009 | 2003 Pontiac Grand Am
1998 Buick Park Ave wont start
Roll down the drivers side window. Close the door. Turn the key to the On position but not cranking. Let it sit there for ten minutes with the key on. After ten minutes turn the key off and then try to start the car. I hope this helps.
Dec 28, 2008 | 1998 Buick Park Avenue
Precor 932i Treadmill Logo
26 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
