Question about Life Fitness 95xi Elliptical Crosstrainer
The display panel does not light up, what type of battery to use to replace display panel
Changed battery on my 2003 S-type v6, starts fine, runs fine but all the lights in the dash are on. How can I reset?
Disconnect the battery for 5 minutes and connect it back up again and re-check.
Were these same warning lights displaying before the battery was replaced?
Nov 18, 2015 | 2003 Jaguar S-Type
SHOWS HISENSE ON SCREEN THEN DISPLAY GOES TO BLACK HAS AUDIO NO VIDEO
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 22, 2015 | Hisense Televison & Video
How do i fix black screen when powering up
In some models of LCD screen; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Mar 02, 2015 | Lenovo Computers & Internet
Lcd light problm disply
In some models of LCD displays; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubleshooted. Contact any service technician. The circuit will differ with models and versions.
Feb 19, 2015 | Computers & Internet
Screen very dim and my installer said display is failing. Quote from URC is $135. Is it worth repairing and shipping back to factory? Remote works fine and activating light button does improve display
In some models of LCD TVS; the backlight inverter will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, it can't be replaced. In this case; a panel replacement is the only repair.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Universal URC MX780 IR RF One-way Wand...
What do i need to replace if only 1/2 the picture displays on my Polaroid flat screen tv
Feb 08, 2015 | Polaroid Televison & Video
Hi I Have a Sony LBT LX5 Hi Fi System, the front display panel does not light-up anymore, but the machine still works.
Hello
The display of these type of sets are of vaccum type one, which will have a heater filament inside. Like any other vaccum bulbs, the filaments of these part may get opened; and can be said damaged. It is a glass vaccum unit, can be located just behind the display window, will have to be replaced as a unit. OK.
Jan 04, 2012 | Audio Players & Recorders
Can not reset clock
turn computer over you will see 3 removeable panels not sure wich panel its under so look care fully for a watch type battery make sure its not the type thats soldered in acer dont usually do this. remove battery very carfully use plastic tweezers then buy new battery, size and type on battery. any retail shop that sells battery.
then replace.
hope this helps.
Apr 26, 2010 | Acer TravelMate 5720-6635 Notebook
Radio is on but display is dimmed
Maybe, your radio is having problem with the connection. Check the connection of your radio whether it is properly connected or your give your radio to a repairer for proper servicing. So, the problem is of two types, (1) Connection of the radio to your car or (2) The radio needs to be serviced.
Sep 21, 2009 | 2000 Toyota Avalon
DISPLAY
Hello Torr276,
Sound like you have either a bad LCD panel or a bad Back light inverter. The first thing is to start with the back light inverter. Its much cheaper. Replacing the inverter normally fixes 88% of all set with that type of a problem. You can request this part from www.interactiverepair.com
Best regards
circuitcity
Apr 30, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Life Fitness 95xi Elliptical Crosstrainer Logo
81 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
