Question about Car Audio & Video
So I'm trying to wire my lightning audio S2.250 and I cannot find the plug for my power ground and remoteand I cannot find the plug for my power ground and remote can I just wired it without it somehow plz help.
  • 113 Answers
SOURCE: Amp will not turn off and the Remote wire is correct.
check pwm chip ,may need replacing
Posted on Aug 22, 2007
SOURCE: auto amplifier installation
Does the new deck have a blue wire for remote and a blue/white wire also? The blue one is for a power antenna and shuts of when playing discs or axillary inputs. The blue/white is for power amplifiers and stays on when the deck is on. Also be sure the remote wire that goes to the amp is not pinched and grounded out to the frame of the car. Let me know, and be sure to leave feedback or I don't get paid.
Posted on Oct 03, 2007
hotuna
  • 288 Answers
SOURCE: 3 wire oven with 2 wire source
Your new oven utilizes 220 volts, but it also has some 110 volt features that need a neutral to work properly. Your old oven was wired without the neutral, probably when the house was built. There are 2 answers to your question. #1, no you should have an isolated neutral or common (same thing) wire, so it should have one. #2, if you connect the white on the new oven to the ground wire it will work. The neutral wires are all connected to the grounds at the breaker panel. Look at it if you don't believe me. The ground is there as a safety to you. if you connect the neutral (the white wire on the new oven to ground) you will be eliminating the safety feature on that appliance. So, I do not recommend you connect the white wire on your new oven to the ground wire out of the wall. But if you do it will work, you will just not have any back up protection if there ever is a problem with the electrical on that appliance. I hope this wasn't too confusing, the answer is you will need to wire the oven properly by adding another wire if you want to be completely safe and within electrical codes.
Posted on Dec 06, 2007
Masterrer
  • 33 Answers
SOURCE: case wires to connect to motherboard
Hello!
To connect front usb header see this diagram:
http://www.celtnet.org.uk/images/usb_connectors.gif
To connect front audio header see this:
http://www.celtnet.org.uk/images/audio_connectors.gif
Hope this helps!
Posted on Oct 02, 2008
rteemon
  • 578 Answers
SOURCE: Where does the source ground wire connect to?
remote connection and the unit should work
Posted on Jul 07, 2009
Where can I find the power plug for this amp?
are you sure there is a power plug needed for the amp? very few amps require power plugs. you merely have to run wires to the power terminal. the power terminal should be labeled - pwr (b+), grnd, and rem.
Dec 01, 2010 | Lightning Audio Strike S2.600.2 Car Audio...
No power to amp
check and try finding another grounding spot
May 16, 2010 | Lightning Audio B4.250.2 Car Amp
I have checked all connections to my amp battery,head unit,remote or trigger wire,fuses,power cable,rca leads,ground wire,amp has a green led light on it indicating if it works ok,red if it`s not,light...
Your amp could be in protection mode! Sometimes turning up to high or wires touching will put in protection mode! It will have to be unplugged for a day or two to drain all power out of the memory. Leave accessorie/ignition wire hooked up, just not power and ground wiring. It should reset itself.
Jan 22, 2010 | Lightning Audio B4.250.2 Car Amp
My yamaha reciever has a power problem in that when i switch it on, it only goes on for a few seconds and thereafter goes off.
As long as you're sure the power cord is firmly plugged in, it sounds like the protection circuitry of the unit has likely been activated. This happens when there is a short circuit in one of the connections. Check your speaker wiring connections and make sure all of them are firmly and carefully grounded (i.e. the copper of the wire touches nothing but the proper terminal, and that the wires do not touch each other). Check the connections on the speakers as well. If protection circuitry is the result of a shock or power surge (lightning, strong static, etc.), you can reset it. Turn it to standby mode, unplug it, wait for 30 seconds, then plug it back in.
Jan 20, 2010 | Yamaha HTR-5630 Receiver
Lightning audio b150.2 as soon as +12 is hooked up blows 25 amp fuse and the c2 1000uf/35v capacitors blow???????
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you.
Aug 25, 2009 | Lightning Audio PC2 Capacitor Car Audio...
Amp problem
Are you sure that the terminal isn't shorted to the case of the amp?
If it's not, the amp probably has a shorted output transistor.
If you want to repair it yourself, read through the following page. It explains the basics. Let me know if you have any questions.
Basic car amp repair primer
May 15, 2008 | Lightning Audio b2.250.1 Car Audio...
Need Help
if you know the difference between ground and the power wire just find an area where the ground can be hooked up in vehicle that goes direct to the bolt to the chassis
ground should be thick wire
try a reset on your amp if it has one pull the fuse and put back in this should help but make sure to get that ground fixed first before giving it power again
May 07, 2008 | Car Audio & Video
POWER
Have you connected the remote wire from the stereo to the amp? assuming it has one.
If the stereo has not got a remote wire you can link it from the positive 12 volt on the amp to the remote connection on the amp, usually it's in between the ground connector and the 12volt.
Mar 22, 2008 | Lightning Audio LA1.300.2 Car Audio...
Amp cuts off
So you have an EQ and a Pioneer amp you're trying to hook up to each other? And only some Stinger RCA cable works? And when the lightning audio RCA cable is hooked up, it doesn't turn on? The amp isn't grounding itself through the RCA cables, is it? Check your ground wire and make sure it has a clean contact that's free of rust or any paint that might be in the way. Otherwise, the RCA cables should have nothing to do with an amp turning on or not.
May 07, 2006 | Pioneer GM-X324 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
