Question about D-Link DGS-1008D 8-Port Gigabit Ethernet Switch (790069252747)
What is the default ip address of HP 1810-8 switch?
  • D-Link Master
  • 787 Answers
  • 18 Answers
SOURCE: what is the default ip address of dlink 8port switch.
should be
Posted on May 01, 2009
  • 32281 Answers
SOURCE: ho to reset dlink3226 switch
Have you got a manual for the D-Link switch?
You may find the info in the manual, if you have lost the manual you can download a manual from this WEB site - Use this link :-
Posted on Sep 17, 2009
  • 135 Answers
SOURCE: i want the default ip address, domain name and password
Hi,You can get your expected domain name also getting hosting at just $1.99 per year from this site ,visit here for more details.All the best.
Posted on May 17, 2010
  • 65 Answers
SOURCE: i have dlink switch model
The default IP address for most D-Link switches is
Posted on Jun 13, 2011
  • 142 Answers
SOURCE: What is the default IP
the usual ip add of a Hub or Router or Switch is either or to determine the Ip Add you can check it - Start - Run (for XP) - type Run in the search box and use the Run command - in the Run Box type in "CMD" - a small black box will pop up (that's the command prompt) - then type in "ipconfig" - look for the "default gateway" that's the ip add of the switch or hub or router.
Hope this helps
Posted on Jun 21, 2011
How to assign ip address to hp 1400 switch?
no need of ip driver software in hp website and install...automatically ip will be assigned
Aug 20, 2014 | HP PSC 1401 All-In-One Printer
What is the default IP of HP ProCurve 2510-48 ?
There is no IP address when the switch ships from the factory. It is set by the user and/or the network by DHCP. If you do not know what the IP address was set to, then you'll need to return the switch ti it's factory default configuration. There should be information in the manual for the switch about the default config.
Jul 02, 2014 | HP ProCurve Computers & Internet
2626 default ip procurve
HP 2626 do not have a default IP address, you have to set the IP address on an enterprise class business switch. You can find the manual for your switch at
Dec 23, 2013 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
What is the default ip address for the procurve 2124
Procurve switches do not have a default IP address. you must put an IP address on the switch. You can find a manual for your switch at
Nov 18, 2013 | HP ProCurve 2124 (J4868A#ABA) 24x10/100...
Default ip procurve 2510 48
there is no default ip address on a procurve switch. you have to put an IP address on the switch. You can find a manual for your switch at
Oct 12, 2013 | HP procurve switch 2510-48
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address
Console(config-if)# exit
Console(config)# ip default-gateway
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
J9400b defult ip adress
There should be no default IP address on a 2626 switch. HP Procurve switches are setup by default to get an IP address by DHCP. To execute the factory default reset on the switch, perform these steps:
  1. Using pointed objects, simultaneously press both the Reset and Clear buttons on the front of the switch.
  2. Continue to press the Clear button while releasing the Reset button.
  3. When the Self Test LED begins to blink, release the Clear button. The switch will then complete its self test and begin operating with its configuration restored to the factory default settings.
Be aware, using these instructions will wipe out any configuration you have on the switch
Good Luck
Jan 21, 2012 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
I have Windows XP Pro, SP2, Office 2007, and an HP Photosmart C7280 off a wireless router. Printer scans OK but 9 times out of ten it can't see the PC. DHCP is "on" but printer IP address is sometimes Auto...
The problem is you want to have the printer on a fixed IP address. This can be done by reserving the IP for the mac address of the printer in the router OR simpler just set the IP address in the printer.
Change IP settings
The default setting for the IP settings is Automatic, which sets the IP settings
automatically. However, if you are an advanced user, you might want to manually change
the IP address, subnet mask, or the default gateway. To see the IP address and subnet
mask of the HP All-in-One, print a network configuration page from the HP All-in-One.
NOTE: When manually entering an IP Setting, you must already be connected to an
active Network, otherwise the setting will not stay when you exit from the menu.
CAUTION: Be careful when manually assigning an IP address. If you enter an invalid
IP address during the installation, your network components will not be able to connect
with the HP All-in-One.
To change IP settings
1. Press Setup.
2. Press until Network is highlighted, then press OK.
The Network menu appears.
3. Press until Advanced Setup is highlighted, and then press OK.
4. Press until IP Settings is highlighted, and then press OK.
If the HP All-in-One is already connected to a wired network, you are prompted to
confirm that you want to change the IP settings. Press OK.
5. Press until Manual is highlighted, and then press OK.
6. Press to highlight one of the following IP settings, and then press OK.
• IP Address
• Subnet Mask
• Default Gateway
7. Enter your changes, and then press OK to confirm the setting.
Jul 04, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
How to assign IP address to HP procurve1800 switch?
The 1800 series do not have CLI so you should connect directly to any RJ-45 port.
I quote from the installation guide:
"In the factory default configuration, the default IP (Internet Protocol) address of the switch is and the subnet mask is"
So set your PC IP address in the same subnet and access it through your web browser. If it has not the default configuration, interconnect the switch ports 1 and 2 and reboot it.
Hope this helps,
take care
Dec 31, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Won't print documents from computer! PLEASE HELP! ASAP!
You cannot use an IP number for more then one device. It is an unique identification number. On the PORT section uner the Windows driver, change the last three digits for the Copystar machine, do not change the other ones (keep in mind that it should be unique!). Then go to the copier and thorugh the user panel get into network settings and enter the COMPLETE IP number just typed in Windows. It should work.
Sep 16, 2007 | Copystar CS-1810 Copier
D-Link DGS-1008D 8-Port Gigabit Ethernet Switch (790069252747) Logo
80 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
