Question about Gemmy Toys
Gemmy dead eye drake pirate
Microphone no working
Microphone not working
How to get your webcam microphone to work: Click on Control Panel, Hardwre and Sound, Sound, Recording. You should see your microphone icon with a Green check mark on it. If there is no Green check mark, it means it is disabled. If there is No green mark on Microphone it never works. To enable the Microphone Right click on Microphone and click on Enable. If you do not see the Microphone in the list, Right click on the White space and select Show disabled devices. Then you would see the Microphone. However, if you do not see the green check mark on it, Right click on it and click on Enable. And also Select Microphone and click on Set Default (If Set as default button is active).
If you see the Green check mark on Microphone the Microphone definitely works.
Step 3: Increasing Microphone Sensitivity and Un-muting the Microphone.
1. Select Microphone and click on Properties button.
2. Adjust the slider until to 100 % of its range.
3. If Mute is on, click the mute button to un-mute the device.
4. If Microphone Boost is available, boost the volume.
5. Click OK to make the changes.
Now the Microphone should work. To verify you can test it on the free webcam test tool site.
Jul 01, 2010 | Logitech Webcam
Web cam works but microphone does not work
Hi There, check your microphone settings. Click volume control in the taskbar, and check microphone level. If that doesn't work, try looking in control panel with the microphone settings.
Jan 18, 2010 | Dell Inspiron 6400 Notebook
I CAN SEE OTHER PERSON AND THEY CAN SEE ME BUT CANT HEAR ME BUT I CAN HEAR THEM .WHAT HAVE I DONE WRONG
The problem is either the microphone is not connected/faulty or the wrong microphone is selected in the Skype Audio setting.
To check if the microphone is working - go to Start - All Programs - Accessories - Entertainment - Sound Recorder and do a test recording.
If the sound is doesn't work then open Device Manager - Sound, video and game controllers and check the microphone is enabled and working. If it isn't listed or has a yellow ? against the microphone then you need to install the microphone device driver.
If the microphone is working then open Skype then click on Tools tab -then Options - Audio Settings - then in microphone setting and click on the microphone list to select your model microphone. Then Save your settings.
To test your microphone settings then go to Contact list and select Echo / Sound Test.Service and follow the instructions. If this works then your friends will be able to hear you,
Nov 07, 2009 | Logitech Quickcam Chat Webcam
My internel microphone doesn't work with Skype -
You need to check the Microphone setting in Skype.
Open Skype, Click on Tools - Audio Settings, then in Microphone settings click the down arrow and select the built-in microphone then save the settings.
If the microphone you selected doesn't work then select a different one.
Jul 04, 2009 | ASUS W5Ae PC Notebook
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
Microphone is not working
i have compaq Presario c700 laptop
but my external microphone is not working & also inbuilt microphone is not working.
Feb 02, 2009 | Compaq Presario 700 470024-192 Notebook
Logitech QuickCam Express: Microphone not working
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Dec 08, 2008 | Logitech Quickcam Chat Webcam
USB Microphone for Nintendo Wii
yws it will any microphone designed for the wii will, i have a few singing games and tis microphone and they all work with it.
hope this helps
Nov 18, 2008 | Logitech Vantage USB Microphone for...
Microphone Won't Work
check your cpu port for microphone to motherbord.
or may be microphone may be faulty.
Oct 22, 2008 | Dell Latitude D600 Notebook
Toys Logo
114 people viewed this question
Top Gemmy Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
