Question about Sony Kds-r70xbr2 70" Rear Projection HDTV
Remove back panel from KDS-R70XBR2
Remove back panel and remove front panel. TV to big to fit through den doors
Iconoclast19
  • 18 Answers
SOURCE: Can't Remove Front Panel
From comments at this blog on how to fix lines across Sony Projection TV:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Comment1:
To remove the cover on the KP57WV600, remove the 5 screws behind each of the speakers. Then pull out the bottom center of the grey panel. It is held in by 4 snap type pins. The cover hinges at the top. Rotate up and be careful not to pull out the wires connected to the front panel. Then proceed as directed here.
Comment2: For those with KP-xxWVxxx TV series you need to remove 5 side screws, just behind the faceplate covering the speakers, next - pull out the 4 round-shaped clips on the botton of the faceplate and last - push-in the top part of the faceplate & pull down at the same time to dislodge the 4 large flat-shaped clips on top.
Comment3: My model required me to removee the 5 screws on the rear facing side panels (LH and RH lower facing aft) then with moderate force grab the lowest edge of the gray front face panel and pull out towards your self. Gently supporting the weight of the panel since there are slotted alignment pins at the top of this panel.
Hope this helps! :)
Posted on Jun 05, 2008
  • 2920 Answers
SOURCE: my sony KDS-R70XBR2 70 inch
power supply
Posted on Sep 14, 2008
Slinteriors
  • 8617 Answers
SOURCE: red led blinks 5 times.
The lamp driver ( Ballast) is faulty
Posted on Jun 18, 2009
  • 3 Answers
SOURCE: how remove the Sony Rear Projection TV KDS-R50XBR1
Looking from front of TV, on the right side there is one screw holding the lamp panel, remove this screw and panel, lamp is behind panel, removes easily.
Posted on Nov 10, 2009
  • 1030 Answers
SOURCE: I have a sony KDS-50a2020 I
I have been looking at the manual for this and i do believe to get behind the front panel where the speaker and buttons lie you have to remove the screen. to do this you have to remove the back to get to 4 screws that are inside the set.
Posted on Nov 02, 2010
My KDS-R70XBR2 has a yellow greenish tint
It if the screen is where you see this is likely a bad optical light engine that this set uses. A photo of this taken and posted here would be helpful---the site also has a new feature where you can take a video and upload it with a question.
Dec 20, 2012 | Sony KDS-R70XBR2 70" Television
Change power switch to kds-r70xbr2 70 in. tv
Call Sony for a part number and price---I have not seen a manual power switch fail on any of these AND even if it was bad the remote should still work
what is set doing or not doing?
Dec 14, 2012 | Sony KDS-R70XBR2 70" Television
Replace on off switch to kds-r70xbr2 70 tv
What exactly is the reason for replacement? What is set doing or not?
The remote should still work even if manual switch is bad.
KDS-R70XBR2 Tilt
First is make sure where you have it positioned now the Entire base is supported and the ends of the set are not pulling down on the cabinet--other than that set may have in the menu a tilt adjustment--there will also be a manual one but only an expert should tamper with that---try again if tilted to lift up on side of cabinet that is tilted down
Apr 19, 2012 | Sony KDS-R70XBR2 70" Television
How do I change the projection lamp for my sony kds 60A3000 60in tv?
remove the front panel below the tv screen. Look for a small door with a single screw. Remove the door and slide out the old bulb. Install the new bulb and reverse the steps!
Thank you and best of luck!~
May 27, 2011 | Televison & Video
KDS-R70XBR2, purchased 2006. Bad optical block. ...
This is not illegal. If you were purchasing the part outright, the core charge would be included in the cost of the part and then you would be able to keep it. Not sure why you would want the part anyway, but most replacement parts do have a core charge. This is true for automotive, appliance, and many other industries. Also, just so you know, the optical block that Sony is providing you will be far superior to the original unit. The color performance and optical block life were improved greatly with the revisions Sony made to these units. Sony is the only LCOS manufacture that actually addressed and corrected the problems that occured with this type of display. You should let them do what they need to to get your TV back into working order.
May 20, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
How remove the Sony Rear Projection TV KDS-R50XBR1
the lamp is located if you are standing in front of the tv, on thr right hand side behind the screen on the side of the tv there is a thumb screw that you have to remove with a flat head screwdriver then you can remove the door and see the lamp inside.
Oct 06, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Red led blinks 5 times.
Jun 17, 2009 | Sony KDS-R70XBR2 70" Television
Sony Kds-r70xbr2 70" Rear Projection HDTV Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
