Question about Hitachi EC89 4 Gallon Twin Stack Air Compressor
Hitachi ec12 twin dont turn on makes buzzing noise
Ran low on oil dont start makes buzzing n oise
  • 59 Answers
SOURCE: hitachi ec12 motor hums after drop in pressue
There should be a pressure switch adjustment under the cover of the switch remove the cover and reset.
Posted on Feb 08, 2009
  • 832 Answers
SOURCE: I got a used Hitachi ec12 compressor, it doesn't start.
1.Check the motor first. You can readily see if it's
burned or not. Run a megger test on the motor.
Test run the motor without the compressor.
2. If, it does not run, have it checked at the motor
rewinding shop.
3. Once it is okey, remount the motor, and start it up.
Posted on Nov 01, 2009
odiebugs
  • 949 Answers
SOURCE: Hitachi EC12 plug it in and nothing happens. No
Sure the outlet you plugged into is working, do not use an extension cord.
If there is power, then there is a black box, where the cord enters the unit., in here is the pressure switch, it tells the unit to work,
unplug the unit open it and see if the plate with the spring moves freely
and then try it again, if not you probably need a new one, I would contact
the company and see if there are problems with the unit and see what they will do for repair, or they might have a better option for troubleshooting this unit.
Posted on Feb 12, 2010
SOURCE: I have a Hitachi compressor EC12. Sometimes when
Could be the return valve. Its the small fitting that attaches to the top tank. Unscrew the top nut its about 11/16's, with no pressure in the tank, and make sure the black rubber seat inside slides in and out of the spring loaded cap, easily. If not, sand the rubber until it does slide easily, then apply light oil, to the area you just sanded and re- assemble.
Posted on Feb 24, 2010
louislevel_2
  • 374 Answers
SOURCE: Hitachi EC12 won't refill air after initial startup
hi there,
of course comparative cost buying and repairing make a cost reduction.if your compressor run smooth but tripping,make sure where on the right path of diagnosing of your compressor,we can check if the motor or compressor is shutting off the unit.disconnect the belt from pulley of the motor to compressor,run the motor if still tripping w/o load its better if you have calmp ammeter test,to check the current rating,if it is tripping motor is deffective replace the bearing.f motor is fine sr till tripping check the compressor also the crankcase bearing,replace worn out bearing.have a nice day dont forget to fix my rate.thanks a lot.
Posted on May 08, 2010
My engine is makinng a clackin noise when i start it but when i press the gas it goes away but when i stop a light or something it makes the oise again
Sounds like the oil pickup screen is clogged causing low oil pressure at idle. Oil pumps do not go bad in these cars.
Mar 23, 2011 | 1990 Buick LeSabre
Hitachi EC 12 2hp Air Compressor. Just get a buzz sound when plugged directly into 120v wall outlet. Piston and shaft turn freely. Have installed a new pressure switch. Just turned the compressor on...
Hitachi EC12 Air Compressor Parts : MASTERTOOLREPAIR.COM
Here is a site that says:
1. Are the capacitors good? (They get the motor going).
2. If they are, replace the stator, ($245)
If you don't find a good solution there, I would try taking it to a local motor rebuilder.
Gary
Dec 14, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I started my air compressor for the first time without any oil. Now it makes a buzzing noise. Is there a "simple" solution other than replacing the motor?
Running compressor without out oil generally will damage rod and deposit metal on crank lobe. Metal can be removed using 400 grit sandpaper cut into one inch strips pulling back and fourth untill lobe is clean as new. You will only need to buy the rod(about $20) and one sheet paper. Remove pump/motor from frame, remove two bolts holding cylinder to body and airline and pull up on cylinder to expose piston/rod. Usually the rod will slightly coat the crank with metal and seize. Remove or work rod off lobe. Clean crank area and add fresh oil. Parts available at www.toolpartsdirect.com Good luck
Sep 25, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My Hitachi EC12 builds pressure, shuts off, then air escapes
I have the same compressor with the same problem. I have temporarily eliminated the thermal reset with a piece of 12 gauge hard wire and it runs just fine. However, I do want to replace it before the warm weather come to the north. I tested the draw at 15.5 amps and the reset was a 17 amp. I am told by someone with superior electrical background that I need to install a 20 amp thermal reset in it's place. I have found that mine runs best when plugged directly into a 20 amp circuit and when using an extention cord I have a 10 guage cord that will carry the load needed to run the EC12. I have also changed to 100% synthetic oil.
May 15, 2010 | Hitachi EC12 Portable Electric 2hp Air...
hi there,
May 03, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I have a small Hitachi 2HP compressor,oil lube w/twin green tanks
the air pressure switch is gone, get a professonal 2 fix it just incase anything should go wrong
Nov 08, 2009 | Air Tools & Compressors
Hatachi EC12 Portable Compressor When I start the
well make sure air pressure is not too high. if not just replace it any air supply house carries them
Jul 02, 2009 | Hitachi EC12 Portable Electric 2hp Air...
No air pressure at the hose
It sounds like you have trouble with your pressure regulator. Make sure that the knob for the regulator is turned clockwise to increase pressure. If this doesn't work, you may need to replace the regulator.
May 24, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi ec12 motor hums after drop in pressue
Feb 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC89 4 Gallon Twin Stack Air Compressor Logo
37 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
