Question about Electrolux EIFLW55I Washer
Electrolux eiflw55hiw front load washing machine leaks water into base service has checked 6 times and can not find problem
FitzOriginal
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
JAN_yuanjia
  • 470 Answers
SOURCE: Electrolux EW 1005f washing machine trouble.
try to go for the technician of washing machine, cuz you have the chance to replace it by replacing another board by there old unit that available and compatible to your washing machine
Posted on Mar 31, 2009
  • 4 Answers
SOURCE: Broken front loader washing machine
take the back off and see if the belt has come off. is it draining water? if not make sure nothing is blocking drain pump
Posted on Apr 23, 2009
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
  • 1531 Answers
SOURCE: Washer is not draining. How do I remove the front
you will need to remove the lid first then remove the screws that hold the control panel in place.then you will need to remove the door boot on the front panel. there will be two screws on the bottom of the panel that will need to be removed as well as the screws on the top of the panel.
Posted on Feb 15, 2011
Testimonial: "Thanks so much, really appreciate the quick response!"
How to acess the drain pump on an electrolux front load washer
Good Morning Friend,
I understand you want to know how to access the drain pump on your Electrolux washer, model# EIFLW55HIW. Typically, this is not a do it yourself access, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to access the drain pump with ease. Hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Electrolux EIFLW55HIW Front Load Washer...
Detergent drawer keeps opening
check you have your washing machine level even slightly tilt in front
Feb 09, 2014 | Electrolux EIFLW55HIW Front Load Washer...
Can not open the door
if there is still water in the machine the door will not open try and spin it out again and check pump filter
May 27, 2012 | Electrolux EIFLW55HIW Front Load Washer...
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
My washing machine and dryer is not working. Where
check the required voltage i think your voltage is different than usa it could be as simple a switch i would look on the back of the machine to see what voltage it operates on and call an electrolux dealer
Apr 12, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux EIFLW55I Washer Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
