Question about Singer Inspiration 4228 Mechanical Sewing Machine
Install bobbin case sure properly - Singer Inspiration 4228 Mechanical Sewing Machine
3 Suggested Answers
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
  • 2973 Answers
SOURCE: Singer Quantum XL-1000 - I
I am attaching two photos, I cant say which one is worse, but may help. Both are of a Singer machine.
There is a lug on the casing that has to go into a slot made on the ring where it rotates. The bobbin does not matter as it has to rotate in any case but its casing stays stationer because of this lug.shiela65_0.jpgshiela65.jpg
Posted on Nov 15, 2010
What can i do when the top thread is caught on the bobbin race and loops there?
1. There are many bobbin cases. Make sure the right one is installed. Also, once you have it installed check the handle of the bobbin case to make sure it is going flat with the bobbin case.
2. Check the bobbin you are using. If it is too long it will protrude the length of the bobbin case. It must be able to spin freely.
3. Check the bobbin case on the outside for any rough edges that could hang up on thread.
4. The bobbin tension should be checked. I've attached a guide for this. Your's is the older style.
5. Make sure the top is threaded properly. Especially make sure the thread is going through the thread in the right direction.
Jun 08, 2015 | Brother LX3125 Sewing Machine
How to fix the tangling of top thread on bobbin race.?
Jun 07, 2015 | Brother LX3125 Sewing Machine
Bobbin case wont stay in place when I sew
Most bobbin cases have a latch that must be released to remove or install in the machine. Be sure to hold the latch open while you insert the bobbin case into the machine. Rotate the bobbin case slightly until it feels seated. Then release the latch. If the bobbin case is not latched in place, it will continue to fall out whenever you begin to sew.
Apr 01, 2015 | Sewing Machines
I broke a needle and now it wont pick up bobbin tread
Hello
Make sure the needle is facing in the correct direction,stitches don't form, or skip badly when the needle is turned around.
Put the bobbin in the bobbin case (right way around) leaving a 2-3" tail.
Thread the top of the machine correctly, leaving a 3-4" tail after threading the needle.
make certain your bobbin in locked into position in it's case and the thread is coming from the bobbin in the correct direction. When holding my metal bobbin in my hand, the thread pulls counter clockwise before placing it into my front loading bobbin case.
Also check if the needle is not properly installed in the needle bar,the machine is not threaded properly or the machine needs adjustment or repair..
Feb 12, 2011 | Euro-Pro 416 Mechanical Sewing Machine
The bobbin on my machine isn't working properly; the top thread doesn't complete a full rotation and the thread keeps breaking. I can't get past a few stitches without creating a jam. I have tried taking...
have you taken the bobbin case out and cleaned it. Its a simple process if you look directly at where the bobbin goes in you will see two latches one on either side of the bobbin case, release those and clean this area and oil it, reassemble and then reload. bobbin thread could be old or if the bobbin was wound on a different machine the tension could be wrong for this machine. when reassembling bobbin case make sure that all parts are seated corectly, also sometimes the actual case that holds the bobbin may need to be replaced, if its an older machine it could be worn.
Oct 29, 2010 | Singer 2250 Tradition
Machine jammed
Turn off the power and remove the needle and presser foot.
Open the needle plate and bobbin case and clean the area, removing lint and the jammed thread.
Make sure the bobbin case is properly in place.
There is a maintenance section in the manual to show you how to remove the bobbin case and clean the machine.
Install a new needle with the flat side to the back of the machine.
Rethread the machine with the presser foot up.
Make sure the thread from the bobbin is feeding from the bobbin spool in the correct direction and through the proper guides.
If you need a manual, you can download one at Brother.com.
Mar 10, 2010 | Brother CS-8060 Computerized Sewing...
Jan 27, 2010 | Singer 7442 Mechanical Sewing Machine
I can't keep the lower thread from getting tangled. I have rewound bobbins, cleaned the bobbin case, made sure the bobbin case is in the correct position, and played with the upper thread tension. When...
Ensure that you have routed the bobbin thread properly. Also, if the bobbin case is not installed properly it will give you this problem. Ensure that the protrusion is touching the spring on the body of the machine.
Jan 27, 2010 | Brother CS-6000
Bobbin Case cannot be replaced properly
Make sure there is no thread wrapped around the bobbin case retaining pin in the locking groove. This pin is part of the shuttle hook. I am assuming this is an oscillating machine and the bobbin case is removed to install the bobbin.
Jan 24, 2010 | Sewing Machines
Stitch pattern not proper
be sure that the thread is routed properly. Then check on the bobbin holder, it may be defective.
Sep 05, 2017 | Sewing Machines
Singer Inspiration 4228 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
