Question about Mitsumi (KFK-EA4XT) Keyboard
Driver keyboard ps2 usb - Mitsumi (KFK-EA4XT) Keyboard
How to unlock the key board
if its wireless replace the batteries. if you are using USB keyboard update the driver. use PS2 keyboard to unlock the system login after power on. then plug the USB keyboard to install the driver automatically. all operating system suports USB keyboard and PS2 keyboard but.
Dec 06, 2013 | Computers & Internet
Keyboard doesn't work after boot
Try booting up with the ps2 keyboard.Once in Win 8.1, unplug ps2 and plug in usb keyboard. See if windows will recognize the usb keyboard and if so it should install software and drivers
Nov 19, 2013 | Gigabyte Computers & Internet
Toshiba aspire boots normally but moving the cursor or any key and the screen goes dark.
Try using a PS2 mouse and PS2 keyboard. It may be that your USB ports have lost their setup (assuming that you are using USB or wireless mouse and keyboard). If the PS2 hardware works fine, check that your USB ports are enabled in the BIOS, then check your device drivers in Windows to see that the USB hardware is recognized.
Oct 12, 2013 | Computers & Internet
Dell xps400 usb keyboard driver
http://download.cnet.com/input-multimedia-usb-keyboard/3000-2110_4-108663.html
This package supports the following driver models:
hope it helpa you
Oct 18, 2011 | Dell (002TR) Motherboard
I have an usb adapter for old ps/2 keyboards, which I tried using for the Dell SK8110 Keyboard. But unfortunately, my laptop needs to install this keyboard's driver for it to function. Any idea where I can...
I think you do not need a driver. Generally ps2 keyboards are detected automatically and work just fine. Still you may go to device manager and un-install the keyboard from there. Then reboot the machine. When it starts again it should detect the modem again.
Note, if you are using a usb mouse please change it to ps2 mouse.
Jan 18, 2011 | Dell SK8110 Keyboard
The pc does not recognize the key board and won't let me type. I have even tried a new Dell keyboard...same problem
Ok I am going to assume that you are using a keyboard with a PS2 plug. Try using a USB keyboard. If the USB keyboard does not work check and see if other USB accessories work.
If you are using a device with a PS2 type plug you should check the drivers for PS2 keyboards by opening control panel then click the "system" icon, then the "Hardware" tab, then "Device Manager"
If you are seeing a yellow exclamation mark then the device driver should be uninstalled. it should automatically reload when you reboot. If the PS2 port is bad you will need to have it serviced by a competent technician.
Jun 26, 2010 | Computers & Internet
Why does the keyboard not work when I start up motherboard. all devices and memory are found but then asks to press F1 or DEL but keyboards (usb and ps2) aren't working :( Motherboard is ABIT KN8 Ultra
Hello
Try this.
Unplug usb key board.start pc.plug usb keyboard in.should work.
Try reinstalling usb drivers or chipset drivers for motherboard if above does not work.
Feb 05, 2010 | Abit KN8 Ultra Motherboard
Mouse works fine but cant get keyboard to sync
Might be a defective keyboard. Check and make sure its compatible for windows vista but all keyboards should work with any system.. As well maybe the port on the computer is bad..
Jul 26, 2009 | Sakar 62150 Keyboard
No keyboard after install
Dear Sir,
Here is Some Hints to solve your problem.
1.Check the Bios your PS2 ports are enabled,if disabled enable it.
2.Go to the device manager see your PS2 keyboard Driver enabled or not.If disabled enable it.
4.Finally Check your computer with new keyboard.
if all these are correct... you still have a problem
Deffinately there may be a problem with PS2 port of your computer motherboard,Then only one option is remaining, you can use USB to PS2 Converter Cable,Or a USB Keyboard.
If you have any other query post a comment with more information regarding the problem.I will try to assist you more accurately
Jun 08, 2009 | Iwill XP333-R Motherboard
Mitsumi (KFK-EA4XT) Keyboard Logo
43 people viewed this question
Top Mitsumi Computers & Internet Experts
David Payne
David Payne
Are you a Mitsumi Computer and Internet Expert? Answer questions, earn points and help others
