Question about ViewSonic OptiQuest Monitor
Speakers The built in speakers in my monitor do not produce sound.
  • 661 Answers
You need to ensure that the speaker lne cable is connected, this should be a double ended 3.5 jack plug cable, one end plugs into the back of the monitor, the other goes into your speaker port on the motherboard of your computer, sometimes there is a power cable required too
Posted on Oct 08, 2007
SOURCE:
Pavilion 22bw does it have built in speakers?
Troubleshooting Sound Problems with Monitor Speakers
Not all monitors come with built-in speakers. If your monitor does not have built-in speakers, then you will need to connect an audio cable to an external speaker system to hear sound.
Mar 19, 2013 | Acer V193w LCD Monitor
Does a Dell E197fp monitor have built in speakers
Not in the monitor, there is a sound bar that attaches to the bottom of the screen that is optional that added speakers to that model.
Sep 24, 2012 | Dell E197FP LCD Monitor
I don't have the sound disk anymore and the monitor is not producing any sound. When I try to download the driver my computer says it doesn't recognize my model VA1930wm
The monitor driver is for your computer to recognize all the resolutions your monitor can handle, there is no sound driver for the monitor to work since the monitor built-in powered speakers are jsut that, powered speakers, same as the one you buy if the monitor does not have built-in powered speaker.
You can test the monitor speaker system by feeding it with the MP3 player or any sound sources.
It may have bad power amplifiers IC. You will be better off spending money on a good set of PC powered speaker system that will provide a lot better sound quality than the quarter-size speakers in the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 21, 2011 | ViewSonic VA1930WM LCD Monitor
No sound
Hello
Unfortunately, this monitor does not come out with integrated speakers, thus you need to get additional speakers if you need some sound.
Hope this can be of help.
Kind regards
Andrea
Jan 13, 2010 | AOC 917Sw 19" LCD Monitor
The built-in speakers on my HP w2408h do not work. I checked the sound generating electronics in my HP computer with a headphone. That worked. I plugged in the sound patch cord to the headphone jack in the...
hello bill.. i have a 190 B and not getting sound... checked all sound generating electronics as well.. i wonder are the internal speakers 'gone'? in mine i.e...??
Oct 26, 2009 | HP Computers & Internet
No sound on monitor
First off is your monitor has any speakers on it or capable off producing any sound? Not all monitors comes with speakers attached to it.
Jul 03, 2009 | ViewSonic Monitor Lcd 22in Wide Va2216w...
I can not tell in my monitor has speakers
Most monitors do not have built in speakers and the ones that do have them are usually of fair quality. Look for speaker grills under your monitor's screen. Didn't find speaker grills? You can buy computer speakers at a computer store or at Walmart. Your computer, desktop or laptop, has a green jack that you plug a set of speakers into. The volume control may be on the speakers or on your keyboard.
May 01, 2009 | HP P1130 21" CRT Monitor
2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Apr 03, 2009 | Dell 5650 Computer Speakers
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
No sound on new LG Flatiron Monitor
You need to get a set of powered computer speakers!
I always found that stand alone speakers are much better than the ones in the monitor.
Jerry G.
Apr 30, 2008 | LG Flatron L1919S LCD Monitor
Computers & Internet Logo
101 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
