Tromm model wd 14312rd
The Tromm model wd14312rd don't dry. the screen say dhE, what does that mean?
4 Suggested Answers
  • 334 Answers
SOURCE: LG Tromm WD R8012 Owners manual
GO TO THIS SITE AND LOOK FOR YOUR MODEL NUMBER UNDER WASHERS. http://www.lge.com/us/support/product/support-product.jsp GOOD LUCK.
Posted on Jun 11, 2009
caroldon
  • 17130 Answers
SOURCE: lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Posted on Dec 15, 2011
tbirdfan1
  • 3051 Answers
SOURCE: LG Tromm washer, what does error code ''CL'' mean?
Hello there and welcome to fixya
THE cl is not a error code at all
it SIMPLY MEANS THAT THE CHILD LOCK FEATURE HAS BEEN ACTIVATED
not to dismiss the feature simply press and hold the wash and rinse buttons for a minimum of 5 seconds and release Your machine may be different so you may have to press a different series of buttons like if theree are 2 buttons with the unlock or lock picture on them or shows a child or something like this but it should be 2 buttons that are neded to unlock ok
Hope this is very helpful
Best regards Mike
Lg tromm wd 85485 error code cl mean ?
Dec 15, 2011 | LG Washing Machines
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How do i get the mold out?
A lot of times liquid detergent and liquid fabric softener will cause this. Dry the door seal after use and leave the door open. Don' t use bleach if you're on a septic system. There are products that are septic safe to clean the mold. Powdered detergent and not closing it up after using should help a lot
Mar 01, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer isn't drying anything very well. getting a oe message lg tromm wm2277hm
the OE message means that the machine has not fully drained out all the water. you can try to re set on drain or you may need a service call. hope this helps.
Oct 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Jun 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
May 22, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg washer dryer
The DHE error is dryer heat error. It's a problem with the heating element or thermister. You can find the service manual herehttp://www.appliancefactoryparts.com/content/pdfs/129017-8.pdf
Nov 11, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
