Question about Sanyo TRC-8080 Desktop Cassette Voice Recorder
No rewind, fastfoward, etc.
It powers up, but none of the buttons work: rewind, fastforward, etc. Any suggestions?
  • flyette Jun 17, 2008
    I am also having the same problem. It will play but is stuck in the play position, no rewind, fastforward, etc.
My Sony DCR-TRV740 camera I just purchased (used), has a playback problem with my 8mm's. When I got the unit I cleaned it well with chamois swaps and MG video cleaner(Recommended by all experts it see
You have a clogged video head. It happens. Do not use the chamois again. Instead, purchase an 8mm head cleaner and give that a try. Only use a brand name cleaner - no generics, and make sure it doesn't come from China!
Nov 07, 2014 | Sony Handycam DCR-TRV740 Digital Camcorder
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
Lost manuel for sylvania mp3 player smpk8854b
alright these are the controls
menu is select
the back button is the play button
if you wanna delete something use the fastforward and rewind buttons to go to explorer then select it
then press menu till you are in your music or voice folder or whatever u want to delete then press volume down and use the fastforward and rewind to select yes or no
If you wanna put it on hold press volume down and menu
and that should be it
Jul 09, 2009 | iLO MP3 Player
How do I set the clock on my aiwa cx-N990 desktop stereo?
-power on the stereo
-push the clock button
-press pause on the cassette deck - the hour should be blinking
-press fastfoward/rewind to adjust it up and down
-push pause again to move to minutes
-push ff/rewind to adjust minutes
-push pause one last time
Mar 07, 2009 | Audio Players & Recorders
13inch tv/vcr no fast forward or rewind buttons how do you do these
no clicker with it??? if not ,u can get a universal remote that might run it if u dont have one?? they are like 4.00 at walmart and onthe back of the tv there are numbers or a code u put into the universal remote that u purchace , u progam them into it and it will run ur tv..or vcr..like the original would.... if not its in ur vcr...
Oct 24, 2008 | Televison & Video
Blinking arrow and numbers, won't eject, play, rewind, fastforward
your camcorder must be broken. a specialist should work on that. go to your nearest technician to help you with. they have a tools for that. hope that helps!
CHARCOIS
Aug 08, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
Motorola L7 media player?
windows media player site will help u
Jul 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Button mixup problem?? HELP PLZ!!
it requires a switch block assembly. this part includes the keyboard for play, rewind etc.. part # is 1-477-084-31 part should run you about 30 bucks. Larry
Sep 18, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Emerson EWR20V4
this is more of a belt problem, look for a worned belt.
May 16, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Sanyo TRC-8080 Desktop Cassette Voice Recorder Logo
41 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
