Question about Cell Phones
Como reparar plancha rowenta modelo DZ 9080
No enciende y tampoco calienta
Alan ang
  • 24 Answers
SOURCE: rowenta autosteam iron dz 1700 r
The electronic device is faulty and need to change inorder for the iron to work properly.
Regards
alan
Posted on Feb 24, 2008
premtech
  • 934 Answers
SOURCE: problemas con la plancha
Por favor esté más específico. ¿No entiendo problemas con el plato?
Bill
Posted on Apr 09, 2008
SOURCE: Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Posted on Sep 03, 2008
  • 713 Answers
SOURCE: la tele enciende, pero la
rerun under f12 boot formate then when asked run windows under the last known start up.
Posted on Feb 17, 2011
Como reparar c?digo P1346 en un terios
Como reparar el codigo de error p1346 en una terios '2005 ...
www.faqqq.com/.../como-reparar-el-codigo-de-error-...
Translate this page Question Product: 2005 Daihatsu Terios 1.3 Question Details: Como reparar el codigode error p1346 en una terios View Answers Search Related.
cual es la pieza P1346 de la toyota avanza,ya que enciende
www.justanswer.es > Coche
Translate this page El c?digo P1346 de toyota refiere al sensor de distribuci?n variable del ?rbol de levas o el circuito sensor de posici?n fuera de rango, esto se condice con el ...
P1346 OBDII Escaner Codigo Diagnosticos OBD2
www.copartes.com > Foros > Errores Codigos OBD-II
Translate this page ... Codigo Diagnosticos OBD2. Introduzca el Codigo OBDII a Consultar o bien ABS, Check, Motor, Aceite, etc. ... P1346 OBDII Escaner Codigo Diagnosticos OBD2. Informaci?n ... Como reparar los rotores delanteros de un Kia Optima 2001.
p1346 obdii escaner codigo diagnosticos obd2
Feb 08, 2016 | Cars & Trucks
Mi plancha modelo G1490 no calienta, no prenden los lod diodos wool silk y linen coton y max.
follow this steps and fix it. God bless you
f the iron doesn't heat, make sure power is on to the outlet, check the electric cord , and check the thermostat and replace if necessary. If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Oct 27, 2013 | Tefal T-fal E9421364 Castiron Plancha...
TV MKTV1403
hola. necesito entrar al servicio del tv mktech modelo mktv1403.. gracias...
Jan 05, 2013 | Aiwa Televison & Video
Como reparar falla tv phillips 40-1431nd-mag1xg que no enciende esta conpletamente muerto
I do not speak Spanish, however, It sounds like you are having a problem with your Phillips television.
Could you tell me what the problem is?
Jan 25, 2011 | Philips 27PT5445 27" TV
Por Favor me gustaria que me respondierais a la mayor brevedad posible y en español. Mi lg pdp42,estaba funcionando perfectamente y de pronto se escuchó un ruido,como cuando se va la luz,como si...
Podrias proporcionar el modelo completo de tu plasma?
Cuando proporciones el modelo te indicare donde esta la falla y tambien donde comprar la parte(s) para reparar tu TV.
Sep 12, 2010 | Televison & Video
No enciende y me dijeron que entro agua posiblemente y esta mal la tarjeta madre quisiera saber cuanto cuesta.
busque en alguna tienda local o vea si puede conseguir alguna notebook que sea el mismo modelo, pero que no funcione. Reparar notebooks generalment no es muy convenient, ya que es muy caro comprar las partes de reemplazo
Mar 13, 2010 | Acer Aspire 5315 Notebook
I need an user manual for blaupunkt rcm 148
tengo un reproductor que no enciende y que tampoco lo lee la computadora, y no se si carga porque no marca nada en la pan talla, nadamaas se calienta el reproductor.
Dec 16, 2009 | Car Audio & Video
Mazda 626 a?o 2001, no enciende el motor.
Que code le dieron quando probaron la computadora ? PO..? mire aver si tiene lumbre en las plugas de sparke. Quite una de las plogas y pongala contra un ground de metal. lleve a alguien que le de vuelta a engenio. debe de tener una lumbre fuerte. Si no, puede ser que algo que ver con el coil o algun sensor. .
Nov 26, 2008 | 2001 Mazda 626
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
