Question about Samsung LN32A550 32 in. LCD TV
Screeching sound and vertical green bars at power up
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Samsung TV started Green Vertical Lines screeching sound tv turns off and cable box resets up to 15 minutes before clear picture and sound work.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 20, 2015 | Samsung Televison & Video
Screeching sound and display of color bars with no picture
it is two 1000uf 10 volt capacitors on the power board. the tops of the
capacitors will look like they are bulging. total cost of parts around
five dollars. if you can use a soldering iron and have a half hour to
spare this will fix it .there are alot of polaroid customers that have had
this problem and fixed it themselves. just click on the follwing to see
the video on this fix http://www.youtube.com/watch?v=unuS3CvmWtw
Aug 02, 2009 | Polaroid FLM-3732 Television
My RCA is screeching
You have a bad colorwheel in the light engine. Due to the complexity of the repair, I suggest you call a tech to check this out
Dec 18, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Wont turn on
there may be a short in the system. Bad news: You should have a licensed pro help you diagnose it and fix it. Good news: its fixable.
Aug 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green/blue vertical lines, no pix, screeching
This is a cap problem too.There is a third 1000 microfarad cap near the other 2 I would suggest you replace while you are in there.The instructions are very good and if you follow them carefully it should be an easy repair.If you have a friend who does some electronics and are unsure of your ability it will be duck soup for anyone who can solder.
Aug 22, 2008 | Polaroid FLM-3732 Television
SCREECHING AUDIO
My Vizio (don't know model # off hand, 32" bought at WalMart in Jan), is doing the same thing. It did it once the day I set it up; thinking it was just a glitch or something about my lack of knowledge with HDTVs, I powered it off (the hard way, yanking the power cord, as it won't turn off any other way) and restarted it, everything seemed OK. It did it again around April, same thing, just a glitch I figured. I changed some cables, attached more devices, and it has been doing it about twice a week now.
Sometimes it is the full video lockup, with vertical green lines, and full blast audio screech. A couple times it has only partially locked up the video (green vert lines, but still some movement), and no audio screech. Did it last night most recently, hence my google search.
Anyway, my point is, this is probably more common than we were both thinking, and they know just from your description what the problem is. I would try to have them repair such a known-issue free of charge, even out of warranty.
Jul 19, 2008 | Vizio L32 32 in. LCD HDTV
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Green vertical lines on the screen
Sounds like you may have some bad filter capacitors in the convergence board. Better take a close look at them before they damage the chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 15, 2006 | Hitachi 42V710 42" Rear Projection HDTV
Samsung LN32A550 32 in. LCD TV Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
