Question about Numark CD Mix2
How to connect my numark kmx01 - Numark CD Mix2
Hum in speakers using numark c3fx
Or an earth problem (connecting cable problem) or dirth in potentiometers or some leaking or bad capacitors
Feb 08, 2014 | Numark Industries NUMARK C3FX DJ MIXER
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
Can i connect a numark NDX400 to my sony surround sound its a s master amp?
Yes, you should use CD inputs and should work like a champ, hope it helps..
Oct 16, 2013 | Numark Industries Numark NDX400 Tabletop...
My numark NDX400 is acting strange. When i am
i did have same problem,i sale them in secend hand shope,not trsutfull ndx400 to be honest.after that i buye new numark mix express.that better than ndx400
Aug 03, 2013 | Numark Industries Numark NDX400 Tabletop...
How do I connect my laptop to my numark icdmix3
If you want to mixdown onto your laptop, get a cable with RCA left and right on one end and an 1/8 headphone jack on the other. On the back is a master out w/left + right and go to line in or mic input on laptop. If you don't have a line in, you have to disable the mic signal +4 db setting in control panel/audio properties volume control. Open properties there and add mic volume control, and open advanced to turn off +4db setting.
Mar 04, 2013 | Numark Industries Numark iCDMIX 3 Dual...
How to connect a numark cdn25+g
This should help:
http://www.numark.com/images/product_downloads/cdn25_quickstartguide.pdf
You do need an amp.and a mixer. You mixer should have microphone jacks, and a pream or switch to allow you to use lowZ, High Z or amplified microphones.
Mar 29, 2012 | Numark CDn25 Professional DJ CD Player
Im trying to hook up two sets of passive speaker, one pair is connected to a QSC amp and the other pair is connected to a Kenwood amp. Is this possible without using another mixer like a mackie 1402.
you should be fine, you can get splitters, little adapters to split the input cables into 2, so that you can use one ouytput to run 2 channels. just hook up the output cables to the output on the numark, and use the splitter adapter to split the sound between the 2 amps.
Oct 05, 2010 | Numark CD Mix2
Numark CD Mix2 Logo
18 people viewed this question
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
rhodesworks
Are you a Numark Music Expert? Answer questions, earn points and help others
