Question about Logitech Computers & Internet
M555b mouse does not work anymore how to fix it?
Tried to clean contacts of batteries, contact seems to be there, but it is dead
  • 624 Answers
SOURCE: Mouse left click button does not always make contact.
Hi RPM GUY, I have a couple of these too but what you?re describing is just the button wearing out from lots of use. Since it?s less than one year old it probably still under warranty, taking it apart would definitely void it. I would contact Microsoft hardware support and try for a warranty replacement. If you want to go ahead anyway remove the 2x batteries and you will see a screw inbetween. Remove it and the bottom half will come appart. Let us know if you have any other questions and please don?t forget to rate the post.
Posted on Feb 01, 2007
SOURCE: Logitech LX6 cordless mouse stopped working
noob
Posted on Nov 02, 2008
skotkolr
  • 558 Answers
SOURCE: resetting a wireless mouse
the usb connection and the mouse should have a button both need to be pushed usually the usb connector first then the mouse, or shut down the computer then restart. let me know if this helps.
Posted on Apr 05, 2009
  • 3600 Answers
SOURCE: Microsoft wireless comfort keyboard model 1027
Try resetting the board unplug the usb plug to the wireless device then turn the keyboard over and press the small button on the back of the key board with a paper clip or ink pen, then the light on the device will light up next do the same thing to the mouse some have numbers of the wireless device like 123 others have letters on them like mine A 1 F let me know if you need help.
Posted on Jan 19, 2010
thbestofme
  • 64 Answers
SOURCE: My hp 'wireles mouse quit working curser won't
Heres a Link on how u can resolve this issue.. http://tinyurl.com/y8ek43e
if even after performing all the steps mentioned in the document.. and if ur computers under warranty then contact HP and get the mouse replaced.. ;) but before u do so.. do try to download the updates from HP.. and do inform about all the steps u tried to perform and yes one more thing u can do.. click Start--All Programs -- PC Help and Tools (if its a HP Computer) and open Diagnostic Tool.. and select Communication and run a test on Mouse.. if test fails.. go ahead contact HP.. and get the mouse replaced..
let me know if this resolved ur issue.. regards, guru
Posted on May 05, 2010
Keyless entry remote doesn't open doors anymore on my 05 ford focus
Sounds like the contacts in the buttons are not making contact.. you may want to try taking the remote apart and cleaning the contacts and seeing what happens. If the remote is truely dead you may need a new remote
Feb 01, 2015 | Ford Cars & Trucks
How do i fix logitech mouse
No lights of any kind? First, make sure the battery is put in correctly. It is easy to get them backwards and absolutely nothing will happen. I had a logitech mouse given to me as nonworking and all I had to do was turn the battery around and it worked fine. Second, you might need to try a different brand battery. I have had AA batteries that had short terminals on the + side and would not make contact in the battery box of the mouse. If neither of those work clean the terminals in the battery box really well with a fingernail file or knife or even a fingernail emery board. Sometimes a little corrosion can be in just the wrong place and keep the battery from making contact. If none of these work the mouse has more serious problems than you probably want to tackle, given the price of a new mouse.
Sep 15, 2014 | Logitech Cordless Mouse
Remote may be dead
Check it for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside the battery compartment, before inserting batteries to make sure that the batteries are in good contact.To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts. It has details about how to check a remote control.
Nov 30, 2013 | Sony Rmt-d187a Dvd Remote Control
Control
1) tight the springs contacts batteries with pliers, for better contacts.
2) clean the contacts batteries.
3) open the remote control and clean the Keypads from oxide, dust, and special spray contacts or alcohol.
4) Reset the code again, and try it. if the problem persist, go to the repair shop TV for fix it.
God bless you
Jun 20, 2012 | Toshiba Rem48tvb Remote Control
My keyboard has stopped working. I have chaged
Get another one then, cause it seems that the receiver either changed channels or broke in some way
Sep 27, 2009 | Microsoft Wireless Optical Desktop Comfort...
My batteries are full but camera won't switch on, it's dead!!!
It might be a problem with one of the switches at either the battery or flash card door.
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try.
Sep 26, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Receiver does not seem to be working
Your problem is apparently in your mouse. Look at the bottom of the mouse where the receiver is placed back when not in use, there is a little thin button, it has to be depressed when receiver is in the USB port. Take the battery off, get a new and fresh battery, prior to inserting it back in the mouse, while holding down the small button install the new battery releasing the button simultaneously. Check also that the battery contacts in mouse are clean. Good luck!!! Chawah.
Jul 17, 2009 | Microsoft Wireless Notebook Optical Mouse...
Dell wireless mouse
I had this problem, but only when my batteries were dead. Check the contacts on the batteries to make sure they're working. Are all the buttons failing too? It might be a broken microswitch (or whatever they use these days). It sounds like you're looking at a new mouse if it's not contacts. Unless someone else on this forum has different ideas.
Nov 04, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Mini cordless notebook mouse
You both need to go here, click the link below;
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en
If you can not find your Mini mouse look to the right for - Contact Technical Support. One or the other will help you acheive a fix for your mini mouse.
Good Luck & kind Regards.
& please vote.
Mar 03, 2008 | Logitech Cordless Mouse
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Computers & Internet Logo
20 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
