Question about Chevrolet 1970 CHEVROLET MONTE CARLO Sales Brochure Book
GEN light on in a 1970 chevy monte carlo will start sometimes and had the voltage regulator replaced and still doing this??
Voltage regulator was replaced, car starts when it wants to, and the GEN light stays on when you are either in park or idling at a light when it is running. I think it is the starter the garage thinks its the altenator, what would the best options be as i have had this car being repaired now for 2 years and the garage keeps doing the same things over so now i want to try and figure it out myself
keemo68
  • 1263 Answers
SOURCE: 1995 chev monte carlo high IDLE
what it basically sounds like is you have a vaccum leak. chances are either the vaccum line to the manifold is got a hole in it or your mps(manifold pressure sensor might be on the fritz) if you replaced the manifold gasket it was because you thought you were sucking air and you thought you were leaqning the fuel air mixture some how. take a look for the vaccum leak and i'm sure you will solve this problem... please rate this..thanks
Posted on Sep 01, 2008
  • 31 Answers
SOURCE: 97 Chevy Monte Carlo won't start, security light is on
disconnect battery for 24 hrs so the computer will reset and if that dont work take it to chevy dealer and have them reset it manually
Posted on Mar 27, 2009
SOURCE: wont keep idle, car stalls out
I had this same problem on my 2005 monte carlo, took mechanic a while to figure out it was the idle air control valve. They also replace the idle air control motor.
Posted on Jun 05, 2009
  • 14 Answers
SOURCE: 2003 Monte Carlo SS Hesitates and Dies after running for awhile
The ck engine light should not be ignored, what sensor was shown to be bad ? Have it scanned again and replace the sensor that is bad if it still runs rough you might want to consider a tune up. Plugs, wires, fuel and air filter's and clean the throttle body with some gumout. It could also be the IAC motor Idle Air Control. Good Luck
Posted on Jun 23, 2009
SOURCE: 2001 Monte Carlo battery goes dead over night
9 times out of 10 it is the factory amplifier. I had this same problem and it was the amplifier. Disconnect the amp located in the trunk by the speakers and see if the drain continues. You will not have music, but having the amp replaced with an aftermarket one will solve this problem,
Posted on Jan 14, 2010
I have a 2005 monte carlo that only starts when i touch the gas sometimes
Sounds like a faulty fuel pressure regulator allowing fuel pressure to bleed off.
Nov 13, 2013 | 2005 Chevrolet Monte Carlo
2003 chevy monte carlo security light came on and now car wont start
does it have the v.a.t.s. system...a chip in the key? sometimes the little resistor in the key goes bad..if you have a spare key try it
Feb 08, 2011 | 2003 Chevrolet Monte Carlo
I have a 1995 chevy monte carlo that I hae
Do any dash lights come on when you turn the key on? Does it crank over?
Jul 04, 2010 | 1995 Chevrolet Monte Carlo
Wire diagram 70 monte carlo color code for voltage regulator wires
On regulator, top down:brown, orange, white, dark blue.
Top down again: field on alt...,"r" on alt,... to battery,... to resistor that goes to acc side of ign switch, and through dash light to run side of switch (Same wire splits on it's way there) different if transistor regulator or if regulator is in the alt.
Sep 06, 2009 | 1983 Chevrolet Monte Carlo
Cruise control light on dash
Sounds like a voltage problem. Have Charging, Starting , and battery system load tested.
Oct 12, 2017 | 2001 Chevrolet Monte Carlo
Mar 27, 2009 | 1997 Chevrolet Monte Carlo
Chevrolet 1970 CHEVROLET MONTE CARLO Sales Brochure Book Logo
18 people viewed this question
Top Chevrolet Toys Experts
Electric Dime
Electric Dime
tony wahlman
tony wahlman
ray gallant
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
