We have a IBM 7208-011 10Gb 8mm. tape.
The copy with cpio command takes about 12 hours for 1.5 Gb. of data.
The same copy with tar command takes about 1/3 of cpio's time.
But the main problem is that the copy is not secure. Frecuently when we
verify the copy we find some errors. We've tried with new and old tapes.
This tape is connected to a RS/6000 model 360 which haves: 2 Gb IBM Disk, 2
Gb HP Disk and 9 Gb Micropolis Disk.
If somebody has news of some similar incident or knows the solution please
answer us.
Jos?? Enrique Cebamanos
grin @ibm.net
GRINSA
C/ Tomas Edison 10, Agrupaci??n Nido, nave 13
50014 Zaragoza
Spain
Rating: 0%, 0 votes
See it with : lscfg -v -l rmt0
Their some EC Level on 8mm 5Gb tape drive...
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
: > I can report the same problems with IBMs 8mm Tape. Now we have a new
: > Exabyte 5GB and it works fine. What I can tell you is, that in some
: > cases you can read the tapes again on another day or in another tape
: > drive, although you haven't see any datas some time before.
: When the 7208-012 in our AS/400 died (is the same unit as the 7208-11 in
: our RS/6000), the IBM technician told me the the IBM 7208 units are
: manufactured by ...... Exabyte!
: I don't know if he tells the truth, but is someone should know...
Yes, the 8mm tapes drives that IBM uses are made by Exabyte. You can even
get a software download for the drive, to change to Eprom to a bootable
tape drive. Just call tech support and ask them about that.
Also, FYI, the 128port controller, and RANS are made by Digiboard.
Mark
Rating: 0%, 0 votes
Would that be Exabyte tech support or IBM tech support?
Thanks...
Ed Ravin |If I were not a little mad and generally silly
era @panix.com|I should give you my advice upon the subject, willy-nilly;
|I should show you in a moment how to grapple with the question
+1 212 678 5545 |And you'd really be astonished at the force of my suggestion.
Rating: 0%, 0 votes
Peter van Leeuwen (PvLeeu @rhzuid-west.nl)
R&H Zuid-West B.V.
tel (010) 4477229
Rating: 0%, 0 votes
In article <01bbca42$b6198a40$9e295 @IBM.ibm.net>, "Jos?? Enrique Cebamanos"
[stuff deleted]
try out the <backup> and <restore> commands and set the block size to
1024 (it saves backup time). We have the same tape drive and the above
works for us without any problems. Hope this helps.
Greetings, Lothar
Lothar Guthmann | To be is not to be,
l @gome3.physik.uni-bremen.de | not to be is to be,
l @pc-labor.uni-bremen.de | that is no question.
l @informatik.uni-bremen.de |
Rating: 0%, 0 votes
TC
Thorsten Coordes
ZARM - University of Bremen Tel.: +49 - 421 - 218 - 4330
Am Fallturm Fax: +49 - 421 - 218 - 2521
28359 Bremen e-Mail: t @zarm.uni-bremen.de
Rating: 0%, 0 votes
advise you to try the AIX backup command. The performance is a lot
better than cpio or other stuff. Average backup-speed of 1MB/sec is
possible.
Success,
R&H Zuid-West B.V.
tel (010) 4477229
