Conia LCD tv has white screen. Sound is OK.
Can someone tell me what the menu items are on the OSD. I want to be able to navigate to PICTURE (I need to know which item number it is in the list of items) and then see if I can fix the problem
bmwrider
  • 215 Answers
SOURCE: LCD screen displays menu items but will not display picture capture & won't take pictures
A very common problem with many Digital cameras. It sounds as if you are suffering from either a CCD problem or a video board problem. Impossible to tell without it being on the bench to check. You could dismantle it and check there's nothing adrift such as flat ribbon cables in their sockets or loose plugs and sockets between the printed circuit boards. Watch out for the flash unit it can give you a nasty shock if it's charged. Most cameras seem to built to last as long as the warranty and then die. This keeps you coming back for more. At least you were lucky to get 2 years out of yours before it passed on.
Posted on Jul 12, 2006
  • 62 Answers
SOURCE: OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Posted on Nov 03, 2008
daniel719
  • 240 Answers
SOURCE: phillips model 51pw9363 Convergence Problem
lets see.
you have an up grade for this unit.
replace original ICs with STK 392-120
if you can soldier and clean heat sink of and replace heat sink you can replace thes parts no problem.
serch for them on line cost is from 14$ to 30 each.
hope this helps you
and please give me a godd rating for this advice.
i pay $160 a month for my info and this sigt pays nothing.
thanks.
daniel.
Posted on Jan 13, 2009
dsacco86
  • 1077 Answers
SOURCE: My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
Posted on May 27, 2009
SOURCE: Lock/unlock symbol appears in the middle of the screen
hold the menu button between 10 and 20 seconds until the lock changes to unlock
Posted on Jun 14, 2009
Why is there a white vertical bar down the middle of the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 28, 2015 | Televison & Video
My tv is stuck in retail mode, how do i reset that?
Enter the OSD menu by pressing Menu on the remote or the TV. Press the down arrow to reach Installation (bottom of the list) and then press the right arrow to to enter this menu. Then navigate to Preferences (third in the list) and press the right arrow. Then navigate to Location and again use the right arrow to enter this item. Set the unit to Home instead of Shop. Press OK on the remote to save the setting. Then press Menu to exit the OSD.
If you are using the controls on the TV, use the Volume +/- buttons to navigate left or right in the menus. The Channel Up/Down buttons will let you navigate the vertical menus.
Once in the Home Location, you can adjust the color or brightness. From the Menu, choose TV settings and then Picture.
I hope this helps.
Dec 07, 2010 | Philips 50PFP5332D 50 in. Plasma...
How do I reset my tv to factory settings. samsung 32 inch LA32R81WDx/xSA
On a different Samsung TV, there is a Picture Reset in the Picture Menu on the OSD. (It's at the bottom of the list.) Similarly the sound reset is in the Sound menu. There is no global reset. (If your Samsung TV's OSD menus are different try under the Support menu.)
I hope this helps.
Aug 05, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
How do I return my KDS USA monitor back to factory settings for color?
The KDS has an 'OSD' ("on screen display").
Press one button on the front of the KDS to activate the OSD, and navigate through its various menu-items, to find the "reset" control.
Apr 16, 2010 | KDS K22mdwb LCD Monitor
How do i turn off my lock on my tv
Hello there. This is taken rigth from the manual...
To reset to the default factory settings, follow these steps.
1. Press the MENU button on the remote control to
open the OSD.
2. Press the Navigation (UP/DOWN) buttons to
select the Options menu.
3. Press OK to open the menu.
4. Press the Navigation (UP/DOWN) buttons to
select Factory Preset.
5. Press OK.
6. Press EXIT to close the OSD.
You can find the rest of the manual here.
Dec 03, 2008 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
OK SOUND NO PICTURE
More information is required. What do you have hooked up to the TV and how is it connected? Do you have a menu/OSD (on screen display)?
Jun 25, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
