Question about General Electric WCVH6600H Front Load Washer
GE Front Loader won't spin medium to heavy Loads
Wont spin out if its more than 6 towels its balanced and does not vibrate. Small loads spin fine..
  • Brett Nov 20, 2013
    I think its more like 4 towels.. It never kicks into high gear...
4 Suggested Answers
  • 56 Answers
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
Posted on May 31, 2009
  • 512 Answers
SOURCE: Our front load washer vibrates so much durning the
Yes unit needs to be leveled. Also if you have a wood framed floor in you home these units will not work they shake everything. If floor is concrete then level and problem should be solved.
Posted on Jul 09, 2009
  • 9 Answers
SOURCE: GE WSSH300G Front Load Washer drains, but
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
Posted on May 27, 2011
Speed queen top loader hops and bounces around when in spin mode
Most likely it's out of balance.look in to that .even out your loads
Jan 04, 2017 | Speed Queen Washing Machines
Frigidaire fws747rfs1
The washer tub bearing may be defective, but that is the only thing that I can think of. Are you noticing this on all loads or just heavy items like bath towels and jeans? Are you redistributing the clothes before the final spin, try that. Also do not overload the washer, wash to medium loads instead of one full to the top load. Wastes water but saves on repairs.
Apr 12, 2017 | Washing Machines
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
Front loader tub out of balance
Try running the washer with a small load. Still out of balance? Call a technician.
A very large load or a load with one heavy item is hard to balance. For example, one pillow cannot be spun but two can. Lots of jeans may not spin well. Wash a towel with the jeans.
Check the manufacturer's website for more help.
Mar 22, 2010 | Frigidaire Washing Machines
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
The drum spins wildly out of balance to the point that it wears away the hard white plastic shield at the front. Is there some alignment guide that may need to be adjusted
this is usually caused by uneven loads. if your sure the the loads are evenly balanced check under your washer for loose or dropped parts
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load washer 417-44082400
Check your ettings
one of them has been changed
try using different settings till you get the right one back
otherwise your timer my be malfunctioning
Jan 18, 2009 | Washing Machines
Wont always spin with a medium to heavy load
seams like you need to check your belt
copy n paste this ;
http://www.youtube.com/watch?v=6XIsK3W_Qcg&NR=1
"Was this helpful?"
Jan 16, 2009 | Kenmore 22622 Top Load Washer
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
Open Questions:
See all General Electric WCVH6600H Front Load Washer Questions
General Electric WCVH6600H Front Load Washer Logo
54 people viewed this question
Top General Electric Washing Machines Experts
Sal De
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
