Question about Canon PIXMA MP830 All-In-One InkJet Printer
When I try to use the scanner, I get an error code1780. What next?
    Problem Solver:
  • 21 Answers
Check if the driver is full installed
Posted on Nov 21, 2013
Imagistics all in one copier/fax/scanner im2520f. All is working except the scanner which is giving error code EA21F7.
Try restarting your printer to see if the scanner lense moves properly and not jammed next you need to download the latest driver and suite from manufacturer`s website which shall definatly solve your problem.
Sep 30, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
There is no twain compliant device installed please install one and try again this is the error message was getting while scaning the page. please help me out..
First Install the Printer Driver.
if the Printer Unable o Scan & show the Error -- There is no TWAIN-compliant device installed. Please Install one & try.
Then U Follw this Tricks.It will solve Ur Problem 100 %.
Click on Add devicesClick on Start - search on scanner word -- click on View scanners & cameras -- Next - Selcet Manufacture Name & select the Printer Device Nname - next - Fiinish.
Aug 29, 2011 | HP Laserjet M2727nf Multifunction Printer
My HP Laserjet m1005 mfp is showing error 6, please provide support and help us in solving the error
Jan 24, 2011 | HP LaserJet M1005 Printer
250 error on documate 510 xerox
Symptom: When scanning you receive an error 250. Cause: This problem can be caused by several different things but is often a driver or communication problem. Solution: Here are several solutions that can resolve this problem:
Solution 1 - Check for communication problems
Using any of the following can cause communication errors:
  • USB hubs
  • Docking stations
  • USB extension cables
  • USB cables longer than 6'
  • Connecting the scanner to one of the computers front USB ports (desktop computer only)
Connect the scanner directly to a USB port on the back of the computer (or side for notebook computers) using a 6 foot or shorter cable.
If you still receive the same error message, try a different USB cable.
Solution 2 - Redetect the scanner with Hidden Devices
Windows Vista, XP and 2000 users
  1. Disconnect the power and USB cable from the scanner.
  2. Click here and select "Run" or "Open".
  3. The Windows Device Manager will open.
    • Click on the "View" menu then select "Show hidden devices".
  4. Click the "+" next to "Imaging Devices". This will show all Imaging Devices previously and currently connected to the computer.
  5. Right-click on the Visioneer or Xerox scanner name and left click on "Uninstall".
  6. If the scanner is listed more than one time, uninstall ALL occurrences of the scanner.
  7. IF you see "?Other Devices" in the device manager list, click on the "+" to view the list of Other Devices.
  8. Right click then left click on "Uninstall" for each occurrence of the scanner. The scanner may be listed as any of the following:
    • USB Scanner
    • USB Device
    • Unknown Device
    • 1200 DPI Scanner
    • (Your Scanner Model)
    • (any other scanners or cameras listed here that you no longer use)
  9. Click the "+" next to "Universal Serial Bus Controllers".
  10. Right-click every listing of "Unknown Device" and select uninstall.
  11. Once all instances have been removed from device manager, reconnect the power and USB.
Windows Me and 98 users
  1. Right-click on the "My Computer" icon on your Windows Desktop
  2. Select "Properties" from the list
  3. Click on the "Device Manager" tab
  4. Find "Imaging Devices" and click on the plus (+) next to it to expand the list
  5. Select your scanner, then click on the "Remove" button
  6. IF you see "?Other Devices", click on the plus (+) next to it to expand the list
  7. Select your scanner then click on the "Remove"; button – your scanner may be listed as any of the following:
    • USB Scanner
    • USB Device
    • Unknown Device
    • 1200dpi Scanner
    • (your scanner model)
  8. Close the Device Manager
  9. Unplug the scanner from the computer and from the power
  10. Plug the scanner back in to the computer and power
Solution 3 - Check for power problems
If the power for the scanner is plugged into a surge protector, battery backup (UPS), or extension cord, plug the scanner directly to the wall.
Solution 4 - Check for conflict with other devices
This error can also be caused by a conflict with another USB device.
  1. Disconnect all USB device from the computer (including the scanner), except for you keyboard and/or mouse
  2. Turn the scanner off
  3. Restart the computer
  4. Once the computer has fully restarted, reconnect and power on the scanner
  5. If the scanner works properly at this time, it means there is a conflict with another device on the computer
  6. It may help to isolate the two items by connecting one of them to a USB add-in card
Solution 5 - Test the scanner on a different computer
If possible, you should try the scanner on a different computer. If the scanner works correctly on a different computer, then the problem is environmental and may be related to your chipset. See solution 6 below.
Solution 6 - Check the computer's chipset
This problem can also be caused by the computer's chipset. To check the chipset:
  1. Vista, XP and 2000 users: Click here and select "Run" or "Open".
    ME and 98 users: Right click on 'My Computer', select 'Properties' then click the 'Device Manager' tab.
  2. The Windows Device Manager will open.
  3. Click on the plus (+) next to 'Universal Serial Bus Controllers'.
  4. This list will include your computer's chipset.
  5. The follow chipsets are known to have communication problems:
    • SiS 7001
    • VIA Rev. 5 or later
    • Open HCD
    • ALi
  6. If your chipset is one of those listed above or it is only listed as 'Standard', you can try updating the chipset drivers.
    • Contact your computer's manufacturer for more information.
  7. If the problem persists, you may need to use a USB add-in card.
    • This is a PCI card that will add more USB ports to your computer.
  8. For more information about USB chipset issues, see www.usbman.com.
Jul 12, 2010 | Xerox DOCUMATE 510 Flatbed Scanner
Cannot scan documents
go to device manager look for imaging device (scanner) right click and uninstall. / click scan for hardware changes tab, found new hardware must be appeared and click next / select don't search, i will choose the driver to install / click show compatible hardware and choose scanner driver found and click next. and finish.
Feb 11, 2010 | Fujitsu M3091DC Path-Through Scanner
SCANNER LOCKED IS ON THE DISPLAY SCREEN I HAVE CHECKED THE GREEN BUTTON UNDER THE PAPER TRAY AND THAT IS SET TO UNLOCK. WHEN I TRY TO PRINT THE DISPLAY SCREEN SAYS SCANNER ERROR AND THE SCANNER LOCKED
Hi, what you want to do is, first; (shutdown) your Scanner, next (shutdown) the computer. Disconnect the scanner, and unplug it from the outlet. Disconnect scanner cables from the computer; Note: do not change anything on the computer. Reconnect cables to the computer. Plug scanner back into the power outlet; turn on computer, turn scanner on. This may clear the (Freeze); but the (Error) might appear again. Thanks paul7of9
Jan 05, 2010 | Xerox Phaser 6110 Laser Printer
HP Scanjet 5590 Lamp Error "Bad or fading lamp (error -4430)" Fixable? Can I do it? Best source to purchase?
From HP forums:
The first thing I would do is to make sure your TMA is properly attached. Next, make sure your software is up to date and that any applicable patches have been applied.
Next, what OS are you using? What application are you trying to use to scan with? Can you scan from any other application such as word or another graphics program?
Oct 06, 2009 | HP Scanjet 5590 Flatbed Scanner
Scanner won't turn on. The scanner is plugged in and no other devices are connected to the computer but it won't power on. The power switch is on and the green light isn't. The scanner error is scanner not...
HI,
Please make sure all the cords are connected properly between the scanner and the PC.Next have you tired using another USB cable wire?
Also make sure you have the latest drivers for your scanner.
Try these steps and let me know if you need any more help.
Thank you for using fixya
Jun 29, 2009 | Visioneer OneTouch 8100 Flatbed Scanner
My scanner
scanner error see ur documentation and callservice if necessery
Oct 21, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Error message 00004700h
This souns like a memory error, where the scan is too large for the pc to cope as other programmes running have taken their peice of your RAM, other than that, uninstall the diver in Add/Remove programmes, disconnect scanner. Re-install driver and re connect scanner when prompted and see if the fault goes away. Please rate solution.
Nov 15, 2006 | Umax Astra 2400S Flatbed Scanner
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
