Question about Alfa Network Alfa AP121 Atheros 802.11n WiFi AP/Router
Can't find acsess for alfa ap121 router. The signal is up but is showing no acess unidentifed network
How fixe
We may need more information in order to assist you.
What is the device type your attempting to connect to this wifi router? If by chance a laptop computer are you able to plug a Ethernet cable into the device and into port 1 on the router and access the default start up page. Most routers will use 192.168.1.1 as the default out of the box IP address. If so you can start the configuration of the wifi there and make sure the radio is enabled and set the SSID and passwords. Write them down. Some older laptops, and iPads for instance may not pick up 5ghz wireless signals so you need to enable 2.5 ghz.
Mar 24, 2014 | Alfa Network Alfa R36 AWUS036NH &...
There is no internet connection to the laptop. The arris modem gives internet acess to the PC computer, though. The manual for the Airlink 101 router says to connect the router and MODEM to each other by a...
What you're missing is that ALL the PCs will be connecting THROUGH the router to the Modem. Unplug the PC network Cable from the modem, then plug a network cable from the router's INTERNET port into the modem (where you removed the PC's network cable). Now, plug the PC's network cable into one of the ports on the router (usually 4 or more, marked 1,2,3,4. Think of a Router as a "splitter". It connects to the Modem, then several devices connect to the Router, some of them by wire and some by Wi-Fi. So your desktop PC is connected by wire to the router and your laptop PC is probably connected by Wi-Fi (wire is an option, as well). The Router sorts out all those signals and communicates with the Modem. Sound reasonable?
May 02, 2017 | Arris Comcast Touchstone Telephony VOIP...
Cant fexed
cant fixed what?
If you means wireless connectivity I recommend you to use the Windows default to connect wireless,because we don't know the wireless configuration of your router or wireless signal provider.
let me know about that
good luck
techbelkin
Jan 08, 2011 | OMNI Alfa 500mW AWUS036H USB Wireless...
I need to know how to repair my other laptop, says unidentifed network, but it shows my router, help
First download software that will give you all the info you need to know about your lapto like speccy...and note down your wireless card type....
Downlaod its latest driver on some other system which can connect to net....transfer it your system through pen drive and then install it...
If you can't find updates try them on manufacturers site...
Jan 02, 2011 | Dell Inspiron 1501 Notebook
Belkin Wireless G USB Network adapter 802 11g password
give me the model and brand of your router. The key is in the configuration page of your router. email me at unit_4105@yahoo.com
Jul 02, 2008 | Computers & Internet
Out of range
When I bring up the wireless network manager, it shows a strong signal to connec to the access point (linksys wireless router). But when I try to connect, it indicates that it's either out of range, or can't find a signal. I've checked that the wireless adapter is enabled, (it is), I've updated to the latest driver, my other computer connects just fine to the acess point, I don't know what else to do at this point. Any help much appreciated....
Dec 07, 2007 | Intel PRO/Wireless 2100 MiniPCI 802.11b
WIRELESS NETWORK PROBLEM
u should buy a business class wireless router ie netgear perhaps
Oct 26, 2007 | Computers & Internet
Alfa Network Alfa AP121 Atheros 802.11n WiFi AP/Router Logo
21 people viewed this question
Top Alfa Network Computers & Internet Experts
David Payne
David Payne
Are you an Alfa Network Computer and Internet Expert? Answer questions, earn points and help others
