Question about Mitel 9104-001-000 Power Supply SX-50 (9104001000) Power Supply
How can i change my overflow extension on my sx-50 mitel phone
SOURCE: Need to add a prefix
First of all you must enter the program mode if you have your manual it will tell you how to do this. If not try this. press the # and on the screen should show command and a flashing number with a question mark. Enter the number 700 and press enter. this will get you in the prefixes. use the next key to scroll until you a a line with no numbers, it may take a little bit depending on how many prefixes are entered. Now then you use the arrow key to get past the first 3 digits that are flashing, enter the number 01 for non toll calls arrow over one more time enter the number to access an outside line commonly 9 then the prefix excatly how it is dialed eg.( 001 01 91800 05). Recap the 001 is what number in the list of approved prefixes. 01 is non toll call. 9 is the access number dialed form the room to get an outside line. 1800 is the first numbers dialed to call a number like 1800DIRECT. 05 is the number of digits dialed including 9. If you have any problems with this email me donnie_rawls2002 at yahoo.com. Hope this helps. I had to do this today at a local hotel and it was a bit confusing in finding the right commands and how to get there.
Posted on Jan 08, 2009
pranam
  • 23 Answers
SOURCE: i work at a hotel and my mitel phone (sx-50) will
I have same problem on my sx-50 mitel consol, can any one solve this problem?
Posted on Jul 11, 2010
  • 378 Answers
SOURCE: mitel sx 50.. How to unlock room phone..how to
Attendant
To apply Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number.
• Press the DND ON softkey.
• If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension.
• Press the EXIT softkey.
To remove Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB.
• Press the DND OFF softkey.
Posted on Apr 18, 2011
  • 378 Answers
SOURCE: Is there anyway to disable operator assisted calls
Yes there is. Unfortunately, this is something that you should contact your vendor to set up for you.
Posted on Apr 22, 2011
  • 378 Answers
SOURCE: SX-50 Mitel wake up calls won't go through to
Your Wake up device is in DND.... it either didn't hang up or it didn't answer. You should contact your vendor to have them check the RAD (Recorded Announcement Device).
Unless you know the extension number associated with it (the installers use different numbering from site to site and I couldn't even guess for you), you won't be able to clear the DND. If you do know the ext number... follow these instructions from the attendant console.
Posted on Jun 03, 2011
Why my mitel sx-50 shows message on console no communication?
The phone line between the SX-50 console and the main control is disconnected or the console may need to be rebooted (unplug the phone line then reconnect it). If this doesn't solve it then contact your PBX system support person.
Jul 14, 2014 | Mitel Lands Phones
Printer queue is full on sx-50 attendant console
This is explained in the SX-50 system maintainer's handbook, 2 copies of which came with your SX-50 when it was new. However, this is a pretty old piece of phone equipment (30+ yrs) and when these systems were originally set up by outside service companies, it was not unusual for them to take the manuals so that customers would not be tempted to tamper and would call the service co instead. However, all is not lost. There is a very good Mitel support group on Tek-Tips (www.tek-tips.com) On tek-tips the Mitel forum is under Home->Forums->Wiring Closet->Phone Systems->Mitel Networks Solutions Forum. You will need to register in order to post. Hope this helps.
Apr 19, 2014 | Mitel Superset 4015 Corded Phone
How can i fix lock on mitel sx50 console ?
Lock? Can you elaborate? I hope you've gotten this resolved already.
Mark
Jan 12, 2011 | Mitel 9104-001-000 Power Supply SX-50...
Mitel sx 50.. How to unlock room phone..how to take it off from do not distrub(in room phone)? Thank you so much
Attendant
Oct 13, 2010 | Mitel 9104-001-000 Power Supply SX-50...
CALLER ID
Negative, the SX 50 does not support CID. You can upgrade the Mitel or use a CID Multi line interface to a PC. Here is one such model.
http://www.callerid.com/
If you go to the bottom of the page on the right, click on how it works. Hope this hlpes.
Jan 15, 2009 | Uniden 5.8GHz Cordless Phone
Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
Nov 11, 2008 | Uniden 5.8GHz Cordless Phone
Voice Mail
If you have the SX -200 series 410 then here is your manual.
http://edocs.mitel.com/UG/EN/SX-200_SS410_ug_en.pdf
If you have the SX -2000 series 410 then here is your manual.
http://edocs.mitel.com/UG/EN/2k_410.pdf
It looks like from reading them though, that your IT department (PBX Administrator) will be the people you will need to contact to reset your code. Or if that does not work for you then I would contact Mitels customer support and see if they can walk you through it.
http://www.mitel.com/DocController?documentId=10095
Hope it helps, and let me know if you need more help or information.
Thanks!
Oct 31, 2008 | Mitel Superset 410 Corded Phone...
Computers & Internet Logo
189 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
