Question about Invicta Reserve Subaqua Venom Swiss Quartz Chronograph Watch
Remove a band from invicta venom reserve
How do I remove the band?
escapement
  • 2334 Answers
SOURCE: invicta 6480. band is rubber and stainless. screws
2 screwdrivers at once- one for each screw. Rate me, plz.
Posted on Mar 09, 2010
Testimonial: "thank you!"
escapement
  • 2334 Answers
SOURCE: i have an invicta reserve watch how do i remove
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please
Posted on Mar 14, 2010
  • 3 Answers
SOURCE: How do you remove the links from an invicta
it's not much harder then normal push pins, just a little trick..push the pin out, doesn't matter which way. You will probably have to pull it out with pliers once you get it started.
once that pin is out, the band still won't come apart. There is another pin, a tube actually that the other pin went thru. it connects the center links. to remove it, you have to first remove the outer links. to do this you push them inwards, toward where your wrist would be if you were wearing it. (the links are actually two pieces-the center 'snake-skin' piece, and the outer bars. the outer bars are connected behind the center piece) the outer bars are what you push inward, they will pop out once the first pin is out.
Now you will just have the center piece connected to the adjacent center piece. That second pin (the tube) will just about fall out if you turn the band on its side. Now the bracelet will come apart.
To put back together, just line up the to center pieces, slide in the tube, then put the outer links in from behind the center piece (this actually locks the tube in place) then put in the long pin.
Ideally it will slide in halfway easily, then carefully tack it in fully. if it doesn't get in halfway jiggle the links and tap lightly. Don't use too much force until it's past 2/3 inserted or you will bend the pin.
Posted on Jun 11, 2010
  • 12 Answers
SOURCE: My invicta stainless steel band has two bent
Contact Invicta for cost of repair:
http://www.invictawatch.com/support_files/service_center/ServiceCenter.htm
Posted on Jul 15, 2010
SOURCE: I have an Invicta Venom
The caps are just for decoration. They dont cover anything. To remove the strap, you have to release the spring loaded pins from the underside of the band. There are two on both ends. Reuse the pins with the stainless band but be careful not to have a pin go into the wrong hole because they can't be removed without breaking them!
Posted on Oct 14, 2011
How to remove the band on the Invicta venom reserve
If you are talking about removing the entire band from the case, the Venom uses 2 spring-tension pins on each side, both of which must be released from their holes in the case to free the band. it is a tricky, hard to see procedure, even for a jeweler, but it can be done. I recommend taking the Venom to the jeweler the first time and letting them show you what the attachment looks like. This would make it easier for you to try yourself in the future without scratching the case or becoming too frustrated.
If you must try this yourself, be patient and use a small tool like a mini screwdriver to release the first pin via the small gap on the underside of the band, and then look for the 2nd pin which is further back. A small flashlight may help you see the pins. Then repeat on the opposite end of the band.
Putting the watch band back on the case is somewhat easier, still requiring patience and several tries. Don't lose or damage the pins.
Sep 29, 2015 | Invicta Watches
Invicta venom reserve how to open back for battery replacement
Take it to walmart and have them replace battery
Apr 26, 2015 | Invicta Watches
How to change watch band on invicta angel stainless steel band
Turn the watch over and you will see that the band is attached to the watch with spring loaded pins. There is room to put a spring removal tool in the available slot and depress the spring which will allow you to twist the band away from the watch. Be careful to not loose the spring loaded pin as you may need it to install another band. Almost every watch uses this method of band removal. Those that don't usually have a long screw that is accessible from the side of the watch.
Feb 19, 2013 | Invicta Reserve Subaqua Venom Swiss Quartz...
I have an Invicta Venom #6111 with Poly strap. I want to put a Stainless steel ******** instead. How do I remove the caps covering the Screws holding the ********?
Oct 24, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
How do you remove the links from an invicta subaqua venom stainless bracelet?
Jun 10, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
How do you remove links from the subaqua venom
Find how to remove or add links here: Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524.
Apr 25, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
I have an invicta reserve watch how do i remove the pins to adjust the band
Mar 14, 2010 | Invicta Power Reserve 1948 - 9979 Wrist...
Invicta Reserve Subaqua Venom Swiss Quartz Chronograph Watch Logo
56 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
