Question about Power Acoustik A3000DB Car Audio Amplifier
Need the service manual for the Power Acoustik car Audio Amplifier model # A3000DB
5 Suggested Answers
  • 5 Answers
SOURCE: 600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Posted on Oct 09, 2007
SOURCE: wiring the hi input wires on my power acoustik
yes
Posted on Feb 19, 2009
Professor_V
  • 92 Answers
SOURCE: I have a power acoustik A3000DB 3000W Mono Class D Series Amplier
I HAVE TWO OF THESE AMPLIFIERS MYSELF. IT IS NO DOUBT AN INTERNAL PROBLEM BECAUSE THROUGH THE PROCESS OF ELIMINATION, YOU HAVE DONE ALL THAT YOU CAN DO AND IT POINTS TO THE AMPLIFIER ITSELF. AS FOR THE CAUSE FOR ITS FAILURE, THERE ARE MANY, BUT IT IS MORE THAN LIKELY IN THE INPUT CIRCUITS AS FAULTS IN THE POWER SUPPLY OR OUTPUT SECTION WOULD MORE THAN LIKELY SHOW UP TRIPPING THE PROTECTION CIRCUITRY. IT WILL SIMPLY HAVE TO BE SERVICED. I AM LISTED IN THE REPAIR DIRECTORY OF THIS SITE UNDER THE ZIP-CODE 70360. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE...V
Posted on Jan 06, 2010
brianw74
  • 400 Answers
SOURCE: Power Acoustik PS2-1250 Car Audio Amplifier was
ya... Its not worth fixing.
Posted on Nov 22, 2010
What's the best way to hook up PA3000DB to a Kicker 15' CVR to get the most bass possible....
Honestly, if you have to ask, you should have a pro do it for you.
The few bucks you spend on installation may save a lot of money in burned out woofers and amps and wires etc.etc.
Feb 28, 2011 | Power Acoustik A3000DB Car Audio Amplifier
My amp powers up but no signal from it its not going in to protect mode or anything like that it just wont play
Check your subwoofer for an open line, it may have blown. The voice coil must have resistance. Also, check the wiring inside the box, and from the box to the amp, as well as the RCAs going from the head unit to the amplifier. It all of these connections are fine, send the amplifier in for repairs.
Jan 19, 2011 | Power Acoustik A3000DB Car Audio Amplifier
Internal capacitors keep blowing up after replacements
if it keeps blowing caps, then you must have another problem inside the amp. such as bad transistors or resistors for an example.
Jul 01, 2010 | Power Acoustik A3000DB Car Audio Amplifier
A3000DB Car Audio Amplifier: I hooked it up.It played for ten mins. Now no soun...
no, check your speaker wire inside sub box check your ground wire and you might need to wire your subs in series
May 17, 2010 | Power Acoustik A3000DB Car Audio Amplifier
Red light turns on then fades away
look closer or close one eye and imagine it lights up (;
Jan 17, 2010 | Power Acoustik A3000DB Car Audio Amplifier
Wat kind of wire should i use power acoustic 3000 class d mono block
What does the fuse on the back say? AWG 4 has around a 60 amp capacity, AWG 2 is about 95 amps. I wouldn't suspect you would need larger than 2. Remember the higher the Gauge the more Resistance per foot you have which means more of a voltage drop at higher current.
Dec 16, 2009 | Power Acoustik A3000DB Car Audio Amplifier
Oct 27, 2009 | Power Acoustik A3000DB Car Audio Amplifier
Internal capacitors keep burning
youre overloading the output reduce to at least 4 ohms impedence speakers
Oct 31, 2008 | Power Acoustik A3000DB Car Audio Amplifier
Power Acoustik A3000DB Car Audio Amplifier Logo
47 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
